TheEngineer
Thanks for that Max, it's clear now what the current options are. The Bilstein 5100 cores would be interesting.
Is it possible to have 1-2" spacers with the Monroe full assembled struts on all 4 corners?
@G00se You could run a leveling kit in the front with the struts.
The rears are standard shocks and the ride height is (mostly) determined by the rear spring.
So you would need to buy a spacer for the two rear springs.
