96 door on 98 truck
bigfeet
Barrington, RI
Hello everyone. Would anyone know if a 96 power door wiring harness will plug right in to my 98? I need a door and found a 96, and a 99. Problem is the 96 is cheaper and in better shape. Thank you
915_Tahoe
Your GM Parts Specialist
HELL PASO, TX
Just as long as both doors have the same electric parts then yes it should be plug and play
bigfeet
bigfeet
Barrington, RI
Thank you
Update. The door from the 98 4dr Tahoe did indeed fit my 98 2dr. The wiring harness did not work. There was an extra plug for the rear doors that I just left unplugged thinking everything else should work. No luck. So, I swapped the harness from the smashed door and everything works now.
veteran111
