If I do it I'll definitely be doing the 99-07 duramax package from Glowshift. 3 pods of your choice and the pillar is basically free. I'll probably do narrowband AFR, trans temp with their 4l60e stub sensor and volt or water temp.
Glowshift is nice stuff, just a little pricey.
So I had my t-case serviced last week. Since then, it’s making a really loud clunk noise, both shifting in, and out of 4lo. I don’t expect silence, but it’s definitely louder, as it was very quiet before the service was done. I know there’s not much to it. Just a drain/ fill, and I know the correct Autotrak fluid. Not sure why this would be making so much noise now. I also noticed the switch on the dash will show it’s in neutral even when it’s not on occasion. Thinking the actuator May be on the way out. Thoughts?
@Sam Harris, my NVG246 (NP8) has a very distinct (read: loud) clunk when shifting in and out of 4lo, and it's always been that way, even before the rebuild. The dash light thing happened to me maybe a year before the TC was rebuilt; I'd be going down the road and the switch would suddenly show "N" but I'm still getting power to the wheels. Pulling over and turning the key off and back on would usually correct it for a while. Replacing the encoder motor fixed that, so that would be my first guess. You could check to see if they got the bolts tight on the encoder motor.
The dash switch can be removed and ohmed; if you need that info let me know and I'll post it or reply to a PM.
Sam Harris
Great information! Thanks very much! That’s exactly what I do when the neutral light comes on. Sounds like I need an encoder motor then, or at least check the connection. [emoji106][emoji16]
For a TC fluid change they wouldn't have necessarily done anything with the encoder motor. However, to pull the encoder motor you'll have to pull the front propeller shaft (driveshaft) out of the front diff u-joint and from the TC splined shaft.
I have a Tech 2, recently purchased, and have done a bit of testing but am not all that familiar with it. Happy to make it available to you since you're in the area.
Sam Harris
Thanks so much! That would be great!
JetBlackNali
Vancouver Canada
20190510_122355.jpg 20190510_092657.jpg 20190510_122151.jpg 20190510_122202.jpg Finally got the time to scrub off the winter and give her a cut and polish and take off the winter boots.
mountie
Blk88notch
They look good from far away but up close they are messed up they guy I got them from did not take care of them.
Bombsquad85
Northern VA
Does anyone have the part number for the lower portion of the transmission shifter cable? I cant seem to find the appropriate one? The retaining tabs that the retaining clip holds on to snapped off so I have mine held together with zip ties at the moment
ASG-MikeS
