Hitch Replacement
Sdp1234
Southeastern PA
My 2004 Denali xl had a rusted hitch. Figured it would be easy to replace but it seems the Denali trim provides issues. I purchased a Reese 51201 but it did not have the bolts into the bumper, did not have a mount for the electric connector and did not fit between the bumper cover cutout. I wish I kept the old hitch.....
What make and model hitches fit the 2004 Yukon Denali properly?
View attachment 222367 My 2004 Denali xl had a rusted hitch. Figured it would be easy to replace but it seems the Denali trim provides issues. I purchased a Reese 51201 but it did not have the bolts into the bumper, did not have a mount for the electric connector and did not fit between the bumper cover cutout. I wish I kept the old hitch.....
The reese should have fit, have you contacted them to make sure you got the right part #?
at any rate, draw-tite makes a good product
http://www.draw-tite.com/products/trailer-hitches/AeUCnKDGi1PxWw|pmNRbMp45abhF|9in
S
Sdp1234
Southeastern PA
That hitch doesn't look centered on the frame; are you sure the correct bolt holes were used?
It is centered The cutout on the Denali is not centered, I believe it is because the wiring plug is on the left
S
Sdp1234
Southeastern PA
I purchased the Curt 13422 from Amazon and it fits well. It’s a bit different than stock so I’m still working out how to mount the 7 pin connector. Overall I’m happy so far with it.
AdrienR
