Dropping My 16' Denali
Dearmosd
A LOT of people support Tony's kit and would back that setup. I am about to order the kit from Tony myself here in a week or two because of how many people like his combo
NORCAL SS
SUV SUSPENSION GURU
Pm me ill help you out. Do not change out front springs. Trust me i tested this years ago
L
L's Truck
DC Metro
PM sent!
Thanks! I've definitely seen his work and following which has me leaning toward that way.
Dearmosd
I just placed order for kit and cant wait till i get to install
BMPNUGLS
Mid-MO
I’ve been wanting to do the same thing to my 16 Denali. One question maybe Tony can answer - I’ve seen people use offset DJM sway bar end links in the rear and offset the sway bar a little bit to avoid any contact with other suspension pieces and to better align the sway bar with the drop.....is this necessary or recommend? Because I’ve seen some use them and some not....maybe it depends on how low you go in the rear (say 3” vs 4-4.5”)??
NORCAL SS
SUV SUSPENSION GURU
Nope not needed at that level nothing hits. You can always get it later if you want
albac
