Vibration at 70 or faster
minytrker
Most of the speed limits here are 75mph, at 70mph and high I start getting a vibration, below 70mph I cant feel it. Its 100% not the road. Yukon is lowered 2-4 and just had the alignment re-checked and is perfect. This is a 2015 yukon XL
One or more wheels out of balance or an out of round tire. Maybe a weight fell off?
08HoeCD
I experienced the same dynamic at speeds over 65mph. Rotated and rebalanced the tires to no avail. Finally replaced the tires and found that at least one of the replaced tires was bad. Sometimes they develop issues over time and you don’t notice it at lower speeds.
That's why I mentioned out-of-round tires. I had my 26's balanced twice and still had a vibration at highway speed. Then I took them to a place with the best balancing equipment available and they're the ones that told me 2 of them were out of round by 3-5%. They did balance them perfectly though and the shake is barely noticeable, and only between 65-70 now.
jeff laing
Mine does the same thing But it’s intermittent, I’ve tried different wheels tires everything, I don’t think that’s the issue
dmad1
Go to YouTube and look up Chevy Shake...
cardude2000
Chevy shake. Gotta test drive these things at 75+. I wish there was a sticky about this.
Log it with your dealer immediately. If new you should give them a couple shots at fixing it and then go lemon lawyer route.
Kenny D
Crosby, Tx
I had the same issue with a 99 burb and with my 09 tahoe. Tire guy told me my wheels were bent on the 09, bought new wheels and it came back. I put the front tires on the back and it went away in the steering wheel. I think my issue is with tires on the 09. I could never figure it out on the 99 burb but I never had the used aftermarket wheels checked either.
Big Mama
Virginia
Please let us know what you find. How was the front lowered? Spindles? I’m with the others. A shake not present at lower speed screams balance. A cupped tire would be less obvious at lower speed but still noticeable. As mentioned get dealer involved but be ready for guff from them bc it’s lowered.
M
minytrker
Its lowered with spindles in front and springs in rear, have biggest sway bars, air bags, shocks, its lowered 100% right and everything has been double checked by me and one of my workers (own a performance shop).
Had it re-aligned (twice) and had the tires road force balanced and it made zero difference. I had other SUV owners say its the driveshaft and one said its the transmission.
Its very frustrating it shakes, we drive my 2500 4x4 suburban everywhere cause our 2015 yukon with 1/2 the miles shakes.
Big Mama
Virginia
There have been some bent drive shafts but that’s pretty rare. If the rolling stock is fine take a look at U joints and shafts. A trans issue you would think would show up before 70 mph but it wouldn’t hurt to drop the pan for a fluid change. Otherwise I feel like the dealer is next. Maybe look up any TSB too
08HoeCD
I didn't see if you confirmed whether you tried installing new tires or not. My issue was found to be caused by a bad tire.
All tires are not equal, even the same model by the same manufacturer---some come out of the form bad, and the issue won't reveal itself unless/until you drive at or over a certain speed. They are more common than you think. I used to think it was BS but it happened to me.
I had a new tire that was out of round and caused this same issue.
M
minytrker
Havent tried new tires, thats on the list just hate to spend $800-$1,000 if its not the tires. The people I race with who have had this same issue, none were fixed with new tires.
Just have a shop balance them that can also check for out of round as well as road force balance them. Mine was slightly out of round.
