Door sag
liquify33
Houston
Just to summarize for everyone everything is tight with my new bushings. bushings to hinges and pins to bushings its all legit now but the sag is still there. Possible bent hinges is what i'm thinking.......
That’s gonna take a BFH to fix!
PG01
Up here to the right
I think i need to replace the striker and latch
Striker will adjust up/down and in/out and that should help but from the weight of the door sagging for so long your body and door frame where the hinges are welded to may have been inadvertently bent from slamming and or lifting up on the door to get it to close.
Squirrelsmith
Squirrelsmith
I need to adjust the striker in then because me door isn't sealing. how do you adjust it?
PG01
Star driver, should be able to turn it just like a screw, righty tighty lefty loosey. It will be tight as a mother so i used to use a pair of vice grips to help it along while trying not to mark up the striker. Be sure to mark where it is now, sharpie around it will do, so you have a point of reference.
Squirrelsmith
Squirrelsmith
what about that is adjustable?
PG01
Once you loosen it you’ll be able to move it up/down and in/out...Like i said before. Loosen it slightly, its threaded into a nut that slides around between two pieces of sheet metal to give you up/down AND in/out adjustment.
Squirrelsmith
Squirrelsmith
I got
I didn't realize there was a plate on the back that could move. thanks!
alpinecrick
Western Slope of Colorado
I've needed to do this for about 10 years. Been thinking of buying the cheap engine hoist at Harbor Freight to support the top of the door so I can do it alone. I've got no other way to support the top of the door. Be very interested to see how the new bushings work out.
Engine hoist makes the job a LOT easier.......
cayukon
