2007 Yukon Denali...no compression cyl #8
GMperformance03
Unfortunately I think I bought a lemon. I bought a 2007 Denali XL 6.2 and at the end of November 2018 and replaced both wheel hub assemblies, outer tie rod, & brakes and rotors.
After taking a break from front end repairs (still need to change both lower ball joints) It started misfiring and running really rough. The local dealership diagnosed no compression on cylinder #8 and recommended replacement at a cost of $8,500.00
The Yukon has 221k miles on it and is in average condition (interior) and below average condition (minor rust exterior). Having a hard time figuring out what to do:
1) Buy new ($8,500.00) probably not going to do that.
2) Install used motor (got quote for $3,900.00 installed).
3) cut my losses and try to sell as is.
Any advice would be appreciated. I really like the vehicle just not sure if it’s worth dumping money in at this point.
Thanks
PS - are there any decent GM shops or independent shops in the central Indiana area that can rebuild or have experience with the 6.2 liter engines or any recommendations?
Big Mama
Virginia
Have you done your own compression check? If so I’d move on. Mostly due to the miles and rust. If the trans is a question there’s another 4-5k. If you’re keeping it I’d find a good shop and decide between the reman or rebuild. Not sure what you paid but there are plenty of gmt900 in the south cheap.
G
GMperformance03
Thanks, I paid $6,950 for it. Transmission seems to be okay, but service stabilitrack and suspension system lights have intermittently came on as well since I’ve owned it. I am somewhat mechanically inclined but don’t really have the time or space to do motor swap right now.
What could I expect to get out of it in its current condition? I really have no idea.
I appreciate the advice.
dnt1010
Tennessee
If it runs (however rough) and is driveable then you can probably find someone that does their own work that would pay 2 to 3k for it. People are naturally optimistic and most shade tree mechanics are looking for that type of vehicle to see if they can do a quick fix and turn a profit. They might fix the collapsed lifter in an afternoon and sale it the next day for 5k.....
G
GMperformance03
Here it is if anyone is interested.
Wolfbraid
Winston Salem, NC
Looks really nice. Well the dealership of course will be way too high priced, check out Jasper Engines, they usually partner or have local shops in the area, engines carry a good warranty
G
GMperformance03
Thanks. I thought it would be a good vehicle for my wife and daughter and unfortunately it hasn’t worked out that way. The dealership offered me $1,000 for it but I just can’t go that low. I’m still stuck on weather to try and sell or fix & keep.
G
GMperformance03
I bought it from a private party. It was my fault for trusting the guy, he even said it was meticulously maintained using his special fully synthetic racing oil. I guess that should have been a red flag right there.
I probably will try to keep it and figure something out with the motor. I’m just at a point in my life without a lot of disposable income (finishing up student loans, recently bought house, younger kids ect;). That’s why I bought a 7k Denali not a 70k Denali, lol.
Thanks
With so little money into it, you can fix it up at your leisure. However, the rust is a cancer and you'll have to decide if she's worth it or not.
Fixing just the problem is the least expensive way to go, pop the passenger side head and fix whatever's broke and put it back together and soldier on. Least expensive way to go.
Kraig
Stabilitrac and traction control lights are a symptom of another problem—maybe related to your engine problem.
Did they say what they thought the problem was causing no compression on #8?
If you’re moderately handy and it’s valves or lifters, you can change that and send it down the road or keep it—your choice—without taking a bath on it.
BG1988
Thanks
pull the fuel injector power so you don't burn up the catalytic converter as well
and run it as a v7 banger
if you plan to move it
it only takes a mile or two to burn it out my experience in another car
thompsoj22
Just my opinion, And i am a mech with optimism. I look at the pic and say "i can fix that" but at 59 im wise enough to know that it is a huge amount of work, alot of potential collateral parts and fluids with an unknown finished product "ie service stabiltrak". 221k is alot of miles and with two kids and life keeping you busy i say cut your losses, $7k is a tough hit but you can recover, detail it and list it for $3,350 with the miss disclosed and move on. Buy your wife another car.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Id grab the cheapest junkyard motor I could find, go over the whole thing and slap it in.
Yeah or find a junkyard that will install their junkyard motor for you.
1yesfan
The motor is the sucky part of it, needing replaced. The "fringe" repairs like the hubs is normal maint I think with those miles. Mine went out on my 01 Silverado at about 175k. The truck really nice, maybe a jasper motor is worth putting in?
1yesfan
I would not let a GM shop/dealer touch it. Find a independent shop that has been around for awhile that is known for good work. Stay away from any of the dealers or "chain" repair shops, they can lose any costs if they F up in the numbers they do across the chain. I one off shop with a good rep has more on the line if they mess up and you give them the shit over it. If the Jasper motor has issues anywhere, if there is a jasper shop around I do believe they will work on it, warranty honored there.
Derick
Indy Suburbs
I dont know about your particular motor but the jasper for my ly6 (when I thought the motor was crapped out) was 4k, plus 2500 for install. Not horrible for a quality rebuild.
Escalade2007
