Bug Deflector / WeatherTech Mats
cjlaw73
Medford, NJ
Didn't know whether to put this in exterior or interior since its both. Whats the collective opinion on the stock Chevy deflector and mats versus the aftermarket. Was thinking of getting WeatherTech mats but saw Chevy had their own. Same question on the bug deflector. Thanks.
LT1ZOB
Chevy’s great, except they don’t want to get sued, so the cutout under the accelerator is idiotically large. I remedied that with self adhesive plastic.
Otherwise, they’ve been in all winter, salt, mud, water, they work great, good quality material.
As for the bug guard, I took it off, wife hated the look of it.
38951A70-DFDB-49E4-820F-ADEFBE24005C.jpeg 32354986-0F60-4522-90D0-D70D277EF28F.jpeg
Daddio
Prince Edward County
Charlie, I've had Weather Tech front mats installed for 2 years. They seemed a little flimsy when I first got them, but they've held up very well. They fit almost perfectly! So much so that I use my wash brush, with the water turned down to a trickle, to wash out mud, grit and salt while they're still in the truck ... over the sill and out!!
I thought an older thread had mentioned a similar, less expensive mat, but I can't find it or recall the manufacturers name.
I'm sure Chev is getting their mats provided by one of these guys.
Daddio
I just saw Georges post. My WeatherTech mat has the protection under the accelerator pedal and up the side. No problem with accelerator interference, but I understand GM's concern. However, around the accelerator is one of the major problem areas for salt stains and build-up, so I would want it.
cjlaw73
cjlaw73
Medford, NJ
Thanks for the review. Between kids and the occasional visit to a construction site, I want something easy to keep clean.
cjlaw73
cjlaw73
Medford, NJ
View attachment 220402 View attachment 220403
Didn't notice the cutout. I'll take a look at them.
Yeah, a friend of mine told me to get a bug deflector for my 2009. I never did and it got plenty of scars on the front of the hood so I thought about getting one on my new (to me) Tahoe.
cjlaw73
cjlaw73
Medford, NJ
Was thinking the same thing.
LT1ZOB
Update!
I would NOT buy the GM liners. Went out to vacuum and clean the interior. As careful as I was, seems to me that water flowed off my shoes, between the mat and the self adhesive plastic I put down and made a nice puddle under the mat. Ridiculous, I should have known better. In and effort not to get sued by morons, they created a useless product
LT1ZOB
I can tell you with certainty that it is the GM Accessories mat at fault here. Lined the edges of the carpeting with paper towel. Blasted the firewall area with my power washer thoroughly. Blasted under the truck thoroughly. Took it through a car wash. Pulled off the A pillar trim. Not a drop of water is coming in.
My final conclusion: DO NOT buy the GM liners if you are planning on driving the in a rainy or snowy area. I’m calling GM Accessories tomorrow and will get my money back to buy the superior WeatherTechs. Have them in my vette and camaro. Never an issue.
HiHoeSilver
Away!
Chicago
You could also look at Husky weatherbeaters. They are popular around here as well.
WTSHARK
So. Cal.
I purchased Weathertech mats and a cargo liner the week after I brought my truck home. They have been in ever since and fit like nothing I've ever seen. They're rolled for shipping (at least the cargo mat was) and I put it out onto the driveway (facedown) for a few hours on a warm summer afternoon and they "relaxed" into their perfect molded forms. They've been in the truck since then (August, 2015) and I'll vacuum them, or wipe them out and I went a step further and put the "GMC Rubber Floor mats" over them as well. I don't like the "slick" feeling and the rubber mats covered the plastic weather techs just fine and add a small level of detail. As for the cargo mat in the back, I bought the larger one for my Yukon as I keep my 3rd row folded down most of the time and carry wet, nasty scuba gear around all the time and the mat's rolled edges keep everything off the carpets. It's also flexible enough to allow access to the under floor storage areas, and it's "flexes" allowing me to pull up the third row without having to remove the mat, it just flexes and sticks up a bit behind the seat. They're expensive, but I'd recommend them to protect your investment and allow for cleaning.
These photos were taken just as I put them in for the first time, the cover everything quite well, but there is no longer a gap where they lay up against the kick panels.
mountie
I have Weathertech mats in my front. They fit pretty good. No interference with my peddle. The only issue is the mats do move a little bit. ... even with the 'snap-on' carpet "grabbers" underneath.... they don't grab.
But the mats do the job. ( 2005 Yukon XL )
As for a bug deflector,.... if they are flush on the hood, they are OK, but if they are NOT flush on the hood, I found them to create wind buffeting at the driver's window. ( Not flush, they screw up aerodynamics )
I have the large cargo mat. They move side-to-side. I don't want to cut the access holes for the tie-downs - to secure the mat better..... I want the liquid protection.
MajorFatal
Whitefish, Mt.
As far as cargo mats I'd go w the GMC product. We first tried Weathertech but the fit/flimsiness dn work so we swapped in the black GMC mat and it was way better.
YMMV.
LT1ZOB
Went back to the dealership I purchased them from last November. They reached out to GM. In short, Accessories told us both to go pound sand. Dealer felt terrible, and for a small restocking fee, they bought the mats back from me and chucked them in the trash as they were used.
I ordered the weathertechs in cocoa. They’ll be in tomorrow.
Hrocks
I have used nothing but Weathertech laser cut mats in all of my vehicles for the last 15 years or so. Still have a set that I used in an '07 Escalade that I put in my '10 Tahoe that my son drives to school.
I also took out two sets of brand new Lexus "all weather" mats in our GX460's and replaced them with Weathertech. There are some cheaper wannabes that kind of look like them, but IMO, they have no rival.
Drewphil
