2016 Tahoe LTZ rear lowering?
craigk
I have a 2016 Tahoe LTZ with the magnetic ride and trailering package and would like to bring the rear of the truck down to match the stock front height What do you guys recommend
Thanks Craig
Dearmosd
Take a couple minutes to look through the first three pages of this section. I think you will find 5 posts talking about lowering
C
craigk
Thanks for all the help you guys
this has always been the kind of responces i see on this sight
I was hoping a seller would maybe chime in and we could start something that way thats all
CMoore711
The information you're asking for has been discussed 100 times over and is already on the site. It's not hard to find at all, this site is very user friendly.
So I recommend you do yourself a favor and well... Help yourself.
I spent 10 seconds finding this link for you, you're welcome. Reading the 11 pages in the thread is on you.
https://www.tahoeyukonforum.com/thr...-to-level-the-rear-of-a-2015-up-gm-suv.79757/
Big Mama
Virginia
@NORCAL SS Tony is your suspension guru. I’m not sure how often the site sponsors look at new posts but reach out to Tony. He’ll fix you up. Good luck
C
craigk
Thanks for wasting 10 seconds of your precious life
05Single
afraid of the dark
Well arent you a little ray of sunshine. That's not how we talk to people to this forum. Dude has 12 post, chill
Big Mama
Virginia
Craig, any luck? Did you reach out to Tony? Normally I’d say use 2” lowering springs out back and be done but I’m not sure how magnetic ride control reacts to a compressed shock or if you’d need extenders. My truck is an 07 and that’s what I did but I don’t have your set up.
C
craigk
I have not reached out to Tony but I plan on doing it
Thanks
TooMuchTxn
Houston, TX
I used the McGaughys 2/3" leveling kit. Super simple install and brought the tail down to sit perfectly level. While you're under there i would recommend doing sways as well!
Tk59194
TooMuchTxn,
Can you provide a link or part # for the McGaughy's kit please?
gmydoc
NE Alabama
Thanks Craig
The Accessory Partners 2015-2019 Chevy Tahoe W/Autoride 2 inch rear lowering kit number PRS-27102 works fine. I used this same kit on my 2015 Tahoe LTZ with magnetic ride and auto level ride rear air shocks. It worked as described, now the Tahoe sits level. Their is no difference in ride quality,
Tahoe 2.jpg Tahoe 2.jpg same feel with no downhill look all the time.
Before installing the kit I ordered better grade 8 hardware rather than using the junk that came with the kit, that was my only complaint with the kit components.
The rear springs are replaced along with shock extenders and two links for the level-ride sensors, not a difficult job, I disconnected the level-ride sensor links to avoid pulling or pushing the sensors beyond their intended travel. After that the rear of the chassis must be lifted evenly just enough to unload the spring and shock (right before the wheels leave the pavement) lower shock bolts are then removed. Once the lower shock bolts are out, raise the chassis enough to remove the springs. Transfer the upper spring seats to the new springs and install the springs. Install the shock extenders and install the lower shock bolts. The replacement links require you to pull the ends off and thread the new links onto the ends, at least on the 2015 later applications may be different. Install links and the job is done.
CMoore711
OP I would just go with Tony’s kit here:
https://tbssowners.com/store/index.php?act=viewProd&productId=578
Speaking from experience; It’s complete, great instructions, rides like stock, includes new bump stops for extended travel “free travel mod”. Plus gives you the flexibility of lowering more down the road if you were to ever decide you wanted to go lower than just a “level”.
08HoeCD
lol
That snarky dude cracked me up...and reminded me why I love the 'ignore' feature.
C
craigk
I did get everything installed and the rear lowering kit was excellent and now the rear is level with the front all measurement are at 35 1/2" 20190411_233000.jpg 20190412_010556.jpg
20190301_101707.jpg 4.jpg Bottom 2 pics are when i got the truck
C
craigk
I did have to adjust the headlights down as you can see in the pictures the black line on the cardboard is the line with the stock rear height and then with the rear lowerd the black line is much lower I did have to adjust the lights down 2 1/2 turns to bring it back to the stock headlight level
Durobans
