600+ Mile Fuel Range Club
bfourman
Indiana
Close... and that’s in a 09 2500 with 222k. Averaging 14.9 mpg on the DIC.
I stopped the pump at $80; 31 gallons. Might have squeezed a little more in there but $80 hurt bad enough as it was.
B
BG1988
2.579 that is cheap 80$
91 octane 3.699 to 4.099 around town
I going to stick with Chevron since it works the best
the mileage tanked after using other brand fuels even though they were "top tier" same octane..
it might be a little more expensive but if i get much better MPG it's worth it
Wolfbraid
Winston Salem, NC
A Man after my own heart! I call those drivers my Huckleberries.
Funny I call them Dingleberry's or cling-ons hehee, it's all good. as a Young kid I drafted an 18 wheeler in my 78 Nova, up the NYS thruway.. I think I averaged 18-20mpg, it was amazing(and stupid)
B
BG1988
I did it in my silverado like 2 feet away from the 18wheeler
that 4.8 got 24MPG which is pretty good for a large pickup (248" long)
it had a huge tank 34 gallon
I've tucked in close behind a rig with my Yukon and seen over twenty for a few minutes while running 70+
When I used to work on the water, there was this snowbird who had a beautiful red Magnum power boat with Arneson Surface Drives, two or three, don't remember anymore. She would turn up such a froth that we could do a solid 25 knots while in her wake when our normal lightly loaded speed was 22-23 knots.
PG01
Up here to the right
Hehe, I thought i was the only moron.....
Do it in my honda all the time...
Well, I tried to join the club today and didn't make it! Best I saw was 469 miles on the instant even though at 23 mpg was showing at 40 mph and with more than 26 gallons on board to burn that should have shown 609+ but didn't. Oh, well.
B
BG1988
it takes a few fill up cycles to get it I was at over 700 miles club today...
Start filling up with Chevron or Texaco....91/93 octane from chevron/texaco you can probably get it to 550. these engine can take advantage of the fuel even if 87 is the minimum.. esp if you got Flex fuel and/or VVT..
Has a lot more power in the lower band 1-2k rpm there for better fuel savings... less down shifting or searching for gears on the 4 speed transmissions So you can stay in OD longer
even though it's very slight increase it makes a difference..
Truck has been running E30 and has exceeded the average fuel economy of Chevron and Mobil 93. On the highway doing 71 or so, the converter doesn't even unlock while going over all but the two steepest bridges in the area. She gets about 2/3 of the way up the Thomas B. Manuel Bridge before shifting down to 5th. At 40 mph it gets 23 mpg and if the driver could hold his bladder for 15 hours, just over 600 miles would pass underneath the wheels!
Reuben0524
