Compatible AC Delco Iridium Spark Plug Replacement P/N
Mr_Bill
I cannot seem to find an AC Delco Iridium part number to replace the original platinum plugs (41-974) in our '03 Yukon, 5.3 L engine. We are at the 100k mile service and would like to upgrade to the iridium plugs. Thanks for any help/advice.
915_Tahoe
Your GM Parts Specialist
HELL PASO, TX
From gm I didn't see iridiums, but I did find these other then the original equipment plug.
Gm#19299585 $11.02 ech
Double platinum
HiHoeSilver
Away!
Chicago
41-110
M
Mr_Bill
Double platinum
Thank you for your help. I did see where double platinum is an upgrade from the original single platinum. But, the local GM dealer said they install iridium plugs. Assuming they use GM parts, I was trying to locate Delco's compatible iridium plugs. Maybe it is only available for late model Tahoe/Yukons perhaps with a slight engine modification.
M
Mr_Bill
Thank you for your help. I checked this Delco iridium plug (41-110) at a few parts sites, but they all say this plug will not fit our '03 Yukon 5.3 L engine. Maybe it is only for newer engines.
HiHoeSilver
Away!
Chicago
It fits.
The 974 & 985 were all superceded by 110. Later to save costs, they started listing the 962 platinum. Use the 110.
Also, to save you the trouble now, they changed the gap. The 110 will come pregapped at .04. Don't try to change it, just check them before install.
M
Mr_Bill
It fits.
GREAT! Thanks so much for your help and useful info. Sounds like the 110 is the way to go.
Merc1973
Maryland
Are the single or Double Platinum AC Delco ok to use?
HiHoeSilver
Away!
Chicago
Yes, they're OK. As you can see in the bulletin above, that's actually what they recommend now for the older trucks. General consensus is that this was a cost saving measure for older vehicles (speculative). Most guys on here seem to stick with iridium.
Merc1973
Maryland
Thank you!
veteran111
