Cargo area leak
Bamajake95
I have a 2007 GMC Yukon sle that leaks in the cargo area. Does anyone have the same issue or any ideas as to what it could be? No sunroof and all factory windows to my knowledge.
Sent from my SM-G960U using Tapatalk
Check your weatherstripping.
Yep what Tony said raise up the rear hatch and take a look at the seal in the hinge area's you can also pull the applique's off and see if either of the air vent slots are broken.
Bamajake95
Bamajake95
I checked the stripping it looks good I think it's the boot that goes from the hatch to the headliner. I had some water dropping from there I just siliconed it. Waiting on that to dry and test it again.
Bamajake95
Bamajake95
Thanks for the info!
992dr
Eastern N.C.
Mine used to leak from where the wiring harness entered the body from the hatch.
That seal just wore out over the years I guess.
I ended up using a sealant to hold it in place and haven't had any issues since.
briannorris
