Show off your 2015+ leveled Tahoes and Yukons!
TahoeOn33s
Any particular reason you removed the 3” lift?
It honestly didn't look right, and I was a little concerned on the wear and tear on the steering components. I ended up doing the 5100 Bilstein shocks and have enjoyed them. I upgraded to 22" replicas and went with Nitto Trail Grappler tires 33x12.5's. It looks awesome, but I am getting some rubbing on the control arm at full turn. I have hard that a 1/4" spacer might fix this.
Let me know if you have any more questions. Cheers.
DWSmoot
Charleston, SC
IYO did it look like it needed taller tires? I am thinking about removing my 2” level and adding a 3” lift in front and 1.5 rear and changing the control arms. Would also add 285/50r22 Ridge Grapplers which are 11.7 wide by 33.5 tall. It’s the taller tires I ultimately want. I also have 1.25 bora spacers which puts me right at a 0 offset. Currently have very minor rubbing on back of well liner in reverse with 2” level and 305/50 G2s.
bowersoldfort
7A1661D1-B83B-42BA-9045-534A39BAF115.jpegD7DD46F0-8263-48F3-9411-CCEE2EAAC618.jpegE3235490-026C-49CF-A4B0-533D893C53FE.jpeg
Looking for as many pics of 2 and 4 wheel drive Yukons and Tahoes with front leveling kits.
Let's see them all!
Let's see them all!
G00se
Newport Beach
That's the best looking leveled 15+ I've seen. Well done sir.
Thanks dude. I need to get some better pics. I'll say the ride sucks though with the front shocks leaking. Just posted a thread about it in this section.
Are you able to compare the way it rides now with the Bilsteins to way an MRC Tahoe/Yukon rides when it's working correctly?
TahoeOn33s
It had a little bit of rack which I didn't like, and I had 275/60R/20's Ridge Grapplers on with it. #1 it rode a little rough with the spacers, and #2 the tires didn't work with the leveling kit aesthetically to me. I didn't like the amount of wheel well I had, or the rack. Also going with the 12.5" wide tire changed the stance of the vehicle to me, and I really like it. Only thing I don't like is the rubbing at full turn. You are welcome to shoot me a PM and I will email you or text message you some photos of before and after if you would like. I am 110% happy with the changes made, and love how it looks and rides (although the Trail Grapplers are pretty damn loud on the interstate haha). Hope this answers your questions.
TahoeOn33s
Unfortunately mine didn't have the MRC. So it was just a straight swap for me. I did however keep a 3/4" spacer on the front with the Bilstein adjustable ride height shocks to keep from maxing them out at full height. It rides smooth to me. I didn't think MRC came into play until 2016, but I could be wrong. Mine is a LT if that is the reason.
Cheers.
DWSmoot
Charleston, SC
Changed tires out from Nitto G2 305/45r22 (12” x 32.8”) to Nitto Ridge Grapplers 285/50r22 (11.7 x 33.5). Had been contiplaticing this swap for some time to gain more height. This particular tire is wide for a 285 if any was wondering. Nearly as wide as the 305 I replaced. The ride is a bit better (Softer road feel) with additional sidewall and the overall ride is a tad rougher(expected with a more aggressive tread design) and maybe 10% louder than the G2, negligible. The look, IMO, is soooo much better as far as aggressiveness. I have some trimming/tuck to do on rear of fender well with the 0 offset and the additional 3/4” of height with the 285/50. I have a 2.5”/1” level coming to install which should help slightly. The current 2” RC level is prob really more than 1.75. Current measurements as sits:
Front 39”
Rear 39 3/8”
FF9B7C85-A372-438F-A042-A3AEEF01EA4B.jpeg E096FECC-8852-4FB2-9317-5596A125FDC6.jpeg 78FA0473-57B5-4446-856D-BD8117E2C4DA.jpeg B67AF5C0-B76A-4154-82CB-CD5DD8662324.jpeg D7234CA8-E75B-4EED-A83D-25E8DFD2980F.jpeg
BourbonNcigars
Changed tires out from Nitto G2 305/45r22 (12” x 32.8”) to Nitto Ridge Grapplers 285/50r22 (11.7 x 33.5). Had been contiplaticing this swap for some time to gain more height. Ths particular tire is wide for a 285 if any was wondering. Nearly as wide as the 305 I replaced. The ride is a bit better with additional sidewall and the Ridge Grap is maybe 10% older than the G2, negligible. The look, IMO, is soooo much better as far as aggressiveness. I have some minor trimming to do on rear of fender well with the 0 offset and the additional 3/4” of height with the 285/50. I have a 2.5”/1” level coming to install which should help slightly. The current 2” RC level is prob really more than 1.75. Current measurements as sits:
Front 39”
Rear 39 3/8”
View attachment 216557 View attachment 216558 View attachment 216559 View attachment 216560 View attachment 216561
Looks great.
BlackYukon
I'm kind of a Retard
DWSmoot Sweet ride man. What 2.5/1 leveling kit did you order? I plan on putting the CCM 2.5"/1" on my 2016 Yukon. I'm Curious if there's a big difference in quality between different brands.
Tiki
They are all literally just spacers.
DWSmoot
Charleston, SC
Thanks. Got the front from Summit Performance and the rear from Suspension Maxx because of the rear load leveling brackets. Personally I have had good experience with the billet aluminum.
BlackYukon
Yeah to a certain extent.. There's always going to be a quality difference when you go from cheap no brand ebay levels up to more popular names like RC, CCM, Ready Lift, etc.
Plus some brands have better warranties than others, along with better QC.
BlackYukon
Awesome. Looking forward to the trucks progress.
varminpoolteam
