Is this the issue??
Thebesta94
Dallas, TX
So... I hit a gnarly pothole going about 45mph tonight.. then I started hearing this wonderful sound from the undercarriage.
I got under the car and think I identified the problem but am wondering what yall think...
The sound only occurs when I accelerate and the vehicle is in motion. If it is in neutral I can rev the gas all I want and nothing...
I've attached a video of the sound while driving and picture of what I believe is the CV shaft and the cause of the sound...
Any help would be appreciated or where else I should look for the issue.
Thanks
that is a boot that has come off the rack-n-pinion, the sound i hear seems more like a hub bearing or maybe a brake pad rubbing, could even be a ball joint if it is making the sound when turning the wheels
Thebesta94
Thebesta94
Dallas, TX
Ok, will look at all joints in morning and see if I can see anything obvious.
I was going to do my brakes soon, and it could certainly be that... didnt even cross my mind. my mind tends to always go worst case scenario
from what it's doing you can likely find the problem pretty easy by just jacking up the front wheels and spin them by hand or turn by hand
Thebesta94
Thebesta94
Dallas, TX
Rear u-joint on drive shaft I believe is the culprit!
And floating feeling is because I snapped bracket....
varminpoolteam
