Installed my el cheapo Amazon catch can today. The line that comes with it was garbage so I picked up some 3/8” fuel line from the parts store. The hydro boost doesn’t allow much room to mount it like a vacuum booster, so I had to rig something up with what I had in the garage.
Not a great pic, my led work light battery died.
I was looking at these about an hour ago for my brother's truck. Amazon reviews said the same about the hoses. I know it'll be a while before you can post results, so what's your initial thoughts on it?
Hi-psi
Atlanta, GA
FWIW, the one I installed also came from Amazon. For the money, it's a really nice unit. A little smaller than some of the other ones, but in ways that's better for mounting room, and pretty much a non issue as long as you check/drain it regularly.
https://www.amazon.com/gp/product/B07JQKHW9W
The only change I had to make is the hose barbs that come with it are too big for 3/8" hose which is what we need for our applications.
bfourman
Indiana
Initial impression out of the box is good. The fittings feel kind of cheap but they work. Mine came with 3/8” and 1/2” fittings with O rings. The can seals well but opens easily. I could do with a little more baffling but we will see how well it works. No drain plug but it’s small enough it will be easy to empty.
All in all it’s a decent unit for what I need it to do.
I looked at that one and like the 1/4-turn drain valve. This would be easier for someone like my brother, whom sucks at keeping up with maintenance. 5 ounces is small, but probably sufficient. I drain right at 3 ounces every 5,000 miles so it would work for me. My brother's truck is an '05, so there's a chance his may pass less oil than mine. Thanks for the link and input. I'll add it to my cart for comparison.
That's the idea I got from the pics and reviews. Like I did with mine, I'll probably add a stainless scrubber pad for more filter media. You answered my main concern- how difficult unscrewing the tank to drain is versus getting one with a drain valve. It's for a mechanically-deficient monkey, so ease of use is a high priority.
09 L9H
not a boomer
Upstate SC
Got single-digit MPG out of a tank of E85 last week so I decided to finally do an E85 vs. premium cost per mile calculation. It's a total wash, which confirms mine and literally everyone else's suspicions. Here's what I calculated:
E85 is on average 10 cents less than regular where I live; combined city/hwy I get 10 MPG on E85 and 13 on premium, and that's rounding up. Guess I'll keep running E85 except for longer trips where I need the extra range out of premium.
The taillights I'm currently running are probably 3 or 4 years old now. Long story short, one of the assemblies is starting to flake out on me so I've ordered some new tails. Figured I'd give these a try. Should be here by the end of the week
Those coilovers are never getting installed, are they?
they'll get installed before the taillights do. they are next on the list as soon as it's not below freezing during the weekend. You Floridians don't know how good you have it down there when it comes to doing stuff on your vehicles in the winter and no heated garage.
We do but come April or May we're inside with the air on 68 waiting for November to work on our cars again!
wwiizz
