One tire blew...replace all 4?
broken08
I know, I know. "you have to replace all 4 tires". These are my super expensive studded nokian tires. They have about 5000 miles on them. I just can't imagine the rear diff can't make up for a couple 16ths of an inch without exploding. If that were the case why does it even have a spare tire (which thankfully was in perfect shape today.)
I don't see the AWD system on this POS truck to be so advanced that it would really be THAT picky, so I'm wondering if there is a spec for HOW different the tires can be. Obviously If I drive once around the block on new tires I can replace one tire. So how about twice? Or 100 miles? 1000? 5000? There is a line, so where is it?
This is a $1400 set of tires that still has two winter seasons left. I'm looking for miracles, I know. But i don't want to put another dime in to this awful vehicle. I just need to keep driving it another couple years until I'm at least even on payments since it lost $15,000 in value in two years while simultaneously needing a complete new long block engine as well as about $6000 in non engine repairs. 130,000 miles.
02Lightning
At 5000 miles I would just purchase one tire. What is the size difference? Also, tirerack can shave a new tire down to match the others.
CrashTestDummy
Pearland, Texas
5,000 miles isn't much, but how many years? If they're much over about 4 years old, I'd be considering replacing the whole set.
SnowDrifter
Sasquatch Country
Rule of thumb is replace all 4 if there's more than 2/32" difference between highest and lowest tread on tire
With that said, most placed offer some sort of pro rated warranty in situations such as this.
08HoeCD
I’d replace two at most, but I can’t see the harm in trying replacing just one (1) and monitoring closely for 250 miles to check for any unwanted/unintended consequences.
B
broken08
But side thought; these vehicles come with a spare tire. If it is that serious, then you technically couldn't use a spare
I had a serious puncture to one tire last year on my awd Denali, by dumb luck the tire shop a mile from me had a used identical tire, I eyeballed it, asked how much? he said $40 installed
done... never had a problem it was visibly better on tread by a little bit but I didn't have any issue's at all.
02Lightning
I think the spares are for temporary use, and I’m not sure what type of coupling the transfer case uses. But, I can see it building a lot of heat, trying to keep up with the different size tires and damaging it over time. I had a tire go bad on my car, I ended up buying an ebay tire with a newer date and the same thread depth.
Buford bubba
