Vortec 454/4L80e HD swapped 1999 Tahoe OBS
6.0 Carb Conversion or Stay EFI?
  • Carb Conversion
    Votes: 0 0.0%
  • Total voters
  • Poll closed .
bigfootchiro
bigfootchiro
Largo, FL
Taylor Cable 8.2mm ThunderVolt wires ordered (in blue of course!), along with Bosch Double Iridium plugs, transmission oil filter kit, engine mounts and transmission mounts. Just need valve cover gaskets, oil pan gasket, high torque starter, motor oil/filter, ATF, and she’s good!
bigfootchiro
bigfootchiro
Largo, FL
I'd also change any sensors that are easy to get to while the motor is out.
I’ll look and see which ones those may be. We may run into an issue with running the fuel lines, because the way they terminate into the engine is different on the 454 than 350
bigfootchiro
bigfootchiro
Largo, FL
the pedal out of a hydroboost truck you may have to get from a junkyard out of a 2500/3500 truck or van.
Which model years should I be looking for? Looking at the RV pedal, I don’t think it’s going to work.
bigfootchiro
bigfootchiro
Largo, FL
Gonna have a little fun with the valve covers! Maybe some other things in the engine bay. Don’t mind all the cat food haha. Went to buy one bag, found that some dog in the store pissed all over then, so they offered us $7 off plus an additional 25% off. They’re set for a while haha
bigfootchiro
bigfootchiro
Largo, FL
Exhaust is off, driveshafts out, transmission is out, most of the engine is unbolted. Almost ready to pull!
albac
