Yes i know another build post!!!! This is my MURDER build 2000 yukon
AZGOAT
AZGOAT
SO. ARIZONA
I'm not sure what you mean by bicycle innertube trick but did you try wrapping a ratchet-strap around the circumference of the tire right in the middle of the tread? Works every time for me... especially with heavy-duty tire on construction equipment (may have to sub a chain & binder for the ratchet-strap on those).
with those generals the side wall would not spread for shit even with heavy duty strap,so what i did went to wal-mart picked up 12.5r bike inner tube stretched it around inner bead of rim aired it up a little bit to fill in gap from tire and bead,shit load of soapy water then began filling tire as tire expands if you keep spring soapy water on bead where inner tube is the tire bead will set and push the inner tube off at same time
adriver
Yeah nice start. That was where the factory dual battery setup went on the heavier pickups.
I had the same problem with the washer fluid. Before you buy any parts, you should be able to see the two hose connections from looking up from underneath. If you fill up the container with water, you should be able to see if its leaking out of one the hose connections and just run a new piece of tubing quickly for a buck or two. The one I had to replace ran up to a plastic double male ended connector along the top side of the fender.
Are you willing to share your future plans, or keeping this a surprise?
AZGOAT
AZGOAT
SO. ARIZONA
future surprise... i'm going to keep going fixing everything i can on this beast and try to upgrade failure parts ....i do have a question about the half shafts on this i work for the military and drive a H1 for my service truck and i work in a motor pool to maintain army equipment via light and heavy wheel..would H1 half shafts work they are thicker and heavier duty then ours well hell Ill be servicing one tomorrow guess ill be doing so measuring and checking splines lol....my other project is going to be started very soon it is a 1996 split year so was equipped with obd2 2wd junk 5.0l in it i traded a welder for the truck i like the square ex body style. I bought a 02 Gmc with brand new 5.3l crate motor,brand new trans,rear end that was loaded with Yukon air locker,and i believe 4:56's its also 2wd well needless to say the guy that owned it went to start it after motor install and had a electrical under dash so...3 months later he passed away i purchased it from his widow for $500 i sold a lot of parts body parts off of it i.e. bed,doors,most of interior,hood and donated the money off of parts to his widow all i wanted was rolling chassis with computer and motor trans i'm going to put my 96 c1500 body and bed on the 02 chassis and fully cage it ,ford f100 or 150 i-beam suspension style front end that i will build myself ...that will be my toy for me and my kids to enjoy out in the dunes or around our area... Murder main purpose is DD/tow and mild trail and play in mud during monsoon.... i was wonder when prerunner build starts if you guys wouldn't mind me posting on this thread i know its Tahoe Yukon forum? O and i will check those hoses when i get home today...i have to post up pic of my fleabay catch can mod couldn't get it installed last nite i was waiting around for a guy to pick up my powder coat oven i am selling... but of course no show grrrr!!!! i will tackle it tonight.
AZGOAT
AZGOAT
SO. ARIZONA
OK apologies for not posting in few days i broke a damn tooth, so Ive been hurting dentist 2morrow but he is a pic of my fleabay catch can ,since the fleabay catch can has 2 inlets which just end right inside i used to own a company in phx building beer systems for various bars,Glendale arena , spring training camps for MLB ,i had a SS tap tube that goes inside of a beer tower that had a perfect bend in it,so i slide it threw one of the fittings then flared it so should work just fine on inlet side that away oil/vapors go to the bottom of tank then also filled tank with the tweeker pipe packing SS sos big wire pads things so it keep oil down ... here is catch can ill take more pics tonight of inside,and the way i mode it....
I’ve seen the inner tube trick when mounting stretched tires. Good work so far, don’t stop. I’m already hooked.
AZGOAT
AZGOAT
SO. ARIZONA
OK yes i know its been a while had some life stuff come up...ugh... i just took murder down to get all 5 wheels balanced the because no one in this town had a turbo balance machine and finally getting aliened....
We need more pics of this things that aren't in the middle of the night under a street light, please :D
chadw
ive been trying to follow this, but holy hell its hard to read. is english not your first language?
Fosscore
Liking this build. Keep up the good work and more pictures.
AZGOAT
AZGOAT
SO. ARIZONA
Kinda first and second lmao....im going to get back on updates asap!!! holidays and b days are over tomorrow!!!! I've done few more changes to murder, waiting on my new phone screen to arrive,damn new phone i just bought fell off my bike lift in garage and broke...grrrrrrr but i really want to get back to posting before i lose everyone like everyone else does on other post i notice...build gets strated then just dies and leaves us all hanging...happy holidays to all be safe!!!!
AZGOAT
AZGOAT
SO. ARIZONA
This is just a lot of old stereo stuff i had laying around in shop said why not do a quick install it has since changed ill upload new pic when i get home from this work stuff grrrr....
AZGOAT
AZGOAT
SO. ARIZONA
This is just a quick pic of her sitting in parking lot at work waiting for me to go home. Damn government shut down why cant you let us go home already....Noooo hasn't effected us yet!!!!
AZGOAT
AZGOAT
SO. ARIZONA
OK went out for another smoke break took few more pics with my temp phone, i know the paint is not good but she is getting a fresh paint job this summer when Arizona weather resides to get hot again for some reason we ended up with snow the last few days....But here is my factory antenna chop down so its not so long i didn't want to do basic antenna delete like everyone else, i also picked up a roof rack from a suburban little longer but i plan on a 52 inch light bar and a custom roof rack that i going to fab.
AZGOAT
AZGOAT
SO. ARIZONA
this is second system revamp i guess you can call it lol.... i replaced rear seat with cloth from same suburban ive been getting all the parts off of....my leather seats where shot front and rear so they are all replaced what a nightmare....
AZGOAT
AZGOAT
SO. ARIZONA
i finally finished Aux battery...before i get shit about motor muddy my splash guards are removed ,and when i clean it ill update pics lol pressure washer and 29 deg weather not very fun in the unusual weather we are having. its all 1/0 cable you can kinda see my pos + cable on firewall my neg - is ran under rad plastic cover.
aux batt 1.jpeg aux batt 2.jpeg aux batt.jpeg aux battary cable 2.jpeg motor pic 3.jpeg
AZGOAT
AZGOAT
SO. ARIZONA
This is my rear hatch that i have under construction lol at moment those are slide out draws that EZ close like newer tool boxes all bolted down to floor, holds tow straps,chains,4 way lug,the other one holds my tie down straps,hitch pins. i had this air tank hanging around so cleaned up going to repaint it. its in primer now i just sprayed last-nite.
dizhai
