Yes i know another build post!!!! This is my MURDER build 2000 yukon
AZGOAT
SO. ARIZONA
This Murder from the state i got her delivered in last month.Ill apologies now but i F**king hate 22's on 4wd suv/trucks!!!!
AZGOAT
AZGOAT
SO. ARIZONA
So apparently Murder got a little extra heat under her hood sometime in her life, because someone fubar wiring a stereo from what i can tell amp hot wire they ran arched out ,burned up the cruise control harness,hood light wires,turn signal wiring,and wipers high beam wires, pretty much all the wiring that runs off of your turn signal switch was all dead. So luckily i have a 2000 downer truck for another build that will be next after this DD build.Had a very nice wiring harness i could use,so i chopped out all the old burnt up exposed wiring and began soldering and heat shrinking,all new section of wiring.
hole lot of sodering and heat shrinking.jpeg new harnness in now sodering time.jpeg wiring complete.jpeg wiring complete2.jpeg wiring done new ground strap and made my own harnness stays.jpeg
AZGOAT
AZGOAT
SO. ARIZONA
I was doing some research on adding a aux battery for this girl, so priced out battery tray and wiring all the items needed.I i looked under hood as to where the aux battery sits i was thinking maybe ill just make a battery tray not to hard hell i build Harley drag bikes,Drag cars battery tray to easy. Walked over to my downer truck got to look at it hell i don't need a battery tray in it because its batteries will be in the rear...mmmm idea ill maybe use it. Looked over in the pocket on where it would have a aux but it had some extra emissions nonsense over there ugh but really got to looking at it and noticed that emissions stuff is mounted to a plate with non the less a damn battery hold down clamp ,sure as shit take the one bolt battery tie down out the emissions shit is held down just like a battery so guess what i didnt have to make a thing unbolted my new battery tray and bolted it right in my Murder this downer truck is really saving me $$$$ on this build so far.
AZGOAT
AZGOAT
SO. ARIZONA
I was thinking i missing one thing form that order where the hell is my matching spare wheel.Sure as shit woke up next morning and package was delivered .
AZGOAT
AZGOAT
SO. ARIZONA
started thinking about high 4,and 6 high mods,well i noticed fog lights didn't work so lets start there adjusted them so there not pointed at the ground,check hit the switch DS burnt out shit! ok got new bulb sweet they work switch it fubar the little button is wore out and is broken so going to find junk yard or someone parting out a c/k/hoe/kon with fog light option. while i was at it someone cut out the grill and added mesh well they did a piss pour job on it so instead out looking as ghetto driving around i went ahead pulled the little bs 2 screws that held mesh in and painted the mesh gloss black instead or faded grey and reinstalled it with pop rivets spaced evenly around now its nice and not just going to fall out.while all that was going on i was tired of seeing the damn windshield empty light so i was like hell easy fix add fluid nothing that simple on this lol added a gallon closed hood stud back to take pic of grill fog lights and sure enough damn thing started leaking grabbed funnel started reclaiming it lol ill fix that another day downer truck better have one...lmao
AZGOAT
AZGOAT
SO. ARIZONA
got the new tires mounted up let me tell you ill never do that by hand again,4 tires broken down off of rims,then mounted 5 generals the 5th one was spare. the worst parts was setting the bead good ol bicycle inter tube trick worked perfect.
AZGOAT
AZGOAT
SO. ARIZONA
Front two seats where tore up so temp fix pulled the 2 out of downer truck ,pulled all electrical rails and controls off of mine bam worked out great.
AZGOAT
AZGOAT
SO. ARIZONA
Sounds like you're having some fun. Interested to see where this leads...
always most done catching thread up to date lol ive only had it 1 month ish so far just everyday i try to fix something onit lol
AZGOAT
AZGOAT
SO. ARIZONA
OK so as of Sunday this is where she is sitting like mild 3in key lift ,the z71 moog springs with 3/4 lift blocks and shock extenders in all 4 corners im ordering new shocks this week mine have seen better days and i have all new upper/lower,ball joints coming already and energy1 poly upper and lower control arm bushings (reason im going poly is AZ weather kills rubber)...as of today after work in 15mins im installing my flebay moded catch can.
thumbnail4.jpeg so far after lift and tires3.jpeg so far after lift and tires.jpeg thumbnail3.jpeg
HiHoeSilver
Away!
Chicago
View attachment 209848 View attachment 209849 View attachment 209850 View attachment 209851
Fun look. Keep a good record of how pressing the bushings go for those control arms.
CountryBoy19
Southern Indiana
I'm not sure what you mean by bicycle innertube trick but did you try wrapping a ratchet-strap around the circumference of the tire right in the middle of the tread? Works every time for me... especially with heavy-duty tire on construction equipment (may have to sub a chain & binder for the ratchet-strap on those).
dizhai
