Starting issue
dross99_si
SE Florida
Hey guys 99% of the time our 2007 Tahoe starts up just fine, but once in a blue moon either we turn the key and nothing happens or it starts and the starter doesn't disengage after engine is running (engine turns over and starter continues to crank). It's happened 3 times in the 2.5 years we've had the vehicle. Just happened again yesterday so I think I need to do something about it. Engine started, starter stayed engaged, turned key to off position and waited a second, truck started up and ran no problem. Kind of scary when it happens cause it totally catches you off guard. Thinking either starter itself may need to be replaced or maybe ignition switch is the issue. Not quite sure..
Any of you guys experienced something like this?
from what you are describing I would lean more towards a faulty starter, if it was just not starting I would say something else. being it is so random it's kind of hard to diagnose for sure so personally I would roll the dice and replace the starter, totally a gamble without extensive troubleshooting (at additional cost & time) at least then if it does happen again you can rule out the starter. If you decide to go that route you can order a starter online and save some money also since it's not really a emergency. places like rockauto/ebay/amazon have great prices. rockauto has a 5% discount code in the vendor section also. good luck.
I agree. Sounds like the starter to me too. A little gunk/dirt accumulation could cause that to happen.
dross99_si
dross99_si
SE Florida
You're right. I'll just replace the starter. Doesn't look too hard. I really only posted to find out if there's a common issue people have experienced with these vehicles like a relay, ignition switch or something really random that would cause the issue I'm having.
Thanks for replying!
dross99_si
dross99_si
SE Florida
Update on this: I changed the starter and starter relay and problem still exists. Every once in a while it cranks odd and starts but like sputtering and you turn the key off it still continues to try to start and sputter. Very odd. Any other suggestions?
Not sure if it's starting system or fuel related.
Ignition switch, FPR, fuel pump...
Warriorpluto
Positive battery cable
HiHoeSilver
Away!
Chicago
This reminded me of a thread not too long ago about a truck that kept running when the key was taken out. Anybody else remember that one? @Doubeleive @swathdiver
Don't remember off-hand. Can't think of a solution other than the starter motor for this one either. Maybe the teeth on the fly... errr, flexplate are damaged and holding onto the starter motor gears? I've seen that before on other types.
I guess the next step is monitor the fuel pressure to try and narrow it down, have cleaned the intake/throttle body and maf?, how is the air filter? ran any injector cleaner thru it? some people have reported similar (rough idle) problems and found running some injector cleaner for few tanks fixed the rough idle., have you ever changed the plugs/wires?
dross99_si
dross99_si
SE Florida
Ok so here's the current situation..
Around the same time the starting issue began occurring we were also getting EVAP codes. P0455, P0442, etc.
It all has to be related in some way.
I have replaced the gas cap (stuck with AC Delco), I have replaced the EVAP purge valve (under hood), Replaced the EVAP vent valve (under vehicle by spare tire), threw a new starter on it even though I really doubted the starter was the issue. What the heck the Tahoe has 150k so replacing some parts wasn't a huge deal.
After all this what we are left with is a P0442 (EVAP small leak) that even after cleared will pop up again after about 150-200 miles and the intermittent starting issue which presents as an extended crank with a sputtery/boggy start which only happens maybe once out of 50 starts.
The P0442 and intermittent rough start has to be related in some way. Still chasing this damn ghost.
90% of the time the vehicle starts and runs perfect. Even with the P0442 CEL it runs like normal.
Let me also mention that the rough start and CEL do not happen simultaneously if that makes sense. They are independent of each other and each occurs at random times.
if anyone can help me connect the dots on this I would greatly appreciate it!
dross99_si
dross99_si
SE Florida
Noticing a pattern with the starting issue. Cold starts it never happens. So first start of the day it's perfect. Drive to store. Next start it will happen 90% of the time. Blip the key and let it do it's thing. It will crank for a while and quit. Take key out. Blip key again and it will crank for a while and eventually start all sputtery and then normalize. Almost like it was flooded..
Truck will be fine for the rest of the day.
Leaking injector perhaps or something with the FPR? Neither of which would explain the EVAP code(s) which seemed to start occurring around the same time as this starting issue. Unless the under-hood EVAP purge valve I replaced is defective..
dross99_si
dross99_si
SE Florida
Bump to get this figured out. I'm sure someone else has experienced this issue..
wjburken
Eastern Iowa
Do you have the ability to track your fuel pressure with a scan tool to see if the vehicle achieves a different pressure on the first start of the day compared to the subsequent starts where you come out of the store? I had a situation on my 2007 Yukon where if it sat for any amount of time, it wouldn't start on the first attempt and always start on the second attempt. Ended up being a bad fuel pump that was allowing fuel pressure to bleed off and the first attempt just re-pressurized the system so it would start on the second attempt.
Might try and run some injector cleaner to see if it helps any if you suspect a leaky injector. Do you have any evidence of fuel in your oil?
I don't see where you mentioned if you inspected your flexplate to see if you have any damaged teeth that could cause the starter to have problems engaging or disengaging.
As for the EVAP purge valve, it is not unheard of to get parts that are bad out of the box but before you throw money at it, I would look at your fuel pressure and your flexplate.
dross99_si
dross99_si
SE Florida
Thanks for replying.
I don't have a good scan tool to monitor fuel pressures on the fly unfortunately. No evidence of fuel in the oil. I have used Seafoam and Techron fuel system cleaners in the vehicle. I have not inspected the flex plate but I did throw a new starter at it a few months ago. At this point, I firmly believe it's not an issue with the starter at all.
Always a possibility that I could have gotten a defective purge valve..
The starting issue and P0442 came up right around the same time so they must be related.
Fuel pump/FPR, fuel tank pressure sensor, leaking injector(s), EVAP lines, charcoal canister are other things that may be the culprit. This is such a PITA!
GMT800 2005 Tahoe Z71
Navy Supporting Member
If I read this correctly you are saying that when you experience the problem you are turning the key and cranking the engine and then the engine stops spinning/cranking all of a sudden. There isn't a fuel pressure problem that would cause an engine to stop cranking while still holding the key in the start position. If you are cranking and the fuel delivery has a problem it will not start but the engine will still spin/crank. I always preach the basics. Check every cable/wire connection between the battery and the starter for cleanliness, no corrosion, looseness....etc. Make sure you have a good battery. Some how some way find a way to monitor the fuel pressure from a cold start and shut off and let it heat soak and then the restart, where you seem to have problems. See if you have good pressure either with a manual gauge attached and taped to windshield during drive or just while you are trying to start after the heat soak.
Check all ground wires at the firewall and on the engine. I cannot tell you how many times I read here where strange things happen in some of these threads and it tracks back to a loose connection or ground problem of some sort. If you did the cold start and then try the restart after the heat soak try to just turn the key to the on position, not the crank position, and see if letting fuel pressure build helps with that restart after warm engine. I am still not convinced you have a flex plate problem but you said the starter R&R is easy so remove it and inspect the flex plate as you turn the engine with a tool.
thompsoj22
your explanation of what is happening sounds like the engine failing to start/spin to the prescribed rpm to reach the starter dropout, if the engine does not fully start the starter will remain engaged until the computer realizes the "im running rpm" and the starter drops out/turns off. understand you initiate the start sequence but the computer starts the vehicle and determines when to shut the starter off. if you want to verify this simply "blip" the key to start and let go of it, the starter will continue to crank without you holding the key until the engine is running. Check fuel pressure as stated above, or try cycling the key to ign on/off a few times prior to starting to allow the fuel pump more time to reach necessary rail pressure to initially start the engine and see if the issue can be controlled by this method.
dross99_si
dross99_si
SE Florida
your explanation of what is happening is the engine failing to start/spin to the prescribed rpm to reach the starter dropout, if the engine does not fully start the starter will remain engaged until the computer realizes the "im running rpm" and the starter drops out/turns off. understand you initiate the start sequence but the computers start the vehicle and determine when to shut the starter off. if you want to if you want to verify this simply "blip" the key to start and watch it start itself. Check fuel pressure as stated above, or try cycling the key to ign on/off a few times prior to starting to allow allow the fuel pump more time to reach necessary rail pressure to initially start the engine.
Yes that's exactly how I start the vehicle, I blip the key and let the computer do the rest.
When I'm having the issue (which is becoming very predictable) I blip, let the computer take over as I always do, the starter engages like normal and the engine cranks strong for maybe 5-6 seconds, engine fails to fire up and eventually the computer stops the starting process all by itself. I then turn key to off position, blip again and computer again cycles the starter. This second time around the engine will always start (although it will take a second or two longer than a normal start) and will fire up rough/sputtery and after a second or two the idle will smooth out and all is normal.
Starter itself never acts funny. Ever.
Battery is pretty new and turns the starter perfectly. Never any signs of weakness there.
In this instance I would suspect a fuel delivery problem then. It is time for a fuel pressure monitoring to see what is happening.
dross99_si
dross99_si
SE Florida
Correct me if I'm wrong, but are you saying when I blip and release the key and let the computer take over the starting sequence that if the engine never fires the starter will continue running forever or until the battery goes dead?
In my case the starter will turn for probably 5-6 seconds and the process stops all on it's own (which seems like forever when it NORMALLY only turns for a second or two to fire the engine).
dross99_si
dross99_si
SE Florida
That's exactly what I am thinking. Seems more fuel delivery related than electrical, grounds, starter, etc.
Like I said it's becoming so predictable.
Cold starts it's always perfect 100% never an issue.
2nd start of that day after a quick run to the store 90% chance the starting issue will occur. Same thing every time. Like groundhog day, lol.
D Rollins
