qcon
Huntsville, AL
Got tired of the glare on the screen when I was using the backup camera, so I made a hood for it. First image is the view from the my eyeline. I may modify it a bit so it doesn't cut off the screen, but then again, that might defeat the purpose of the hood.
Wolfbraid
Winston Salem, NC
Looks nice, but being in FL(and the lax tint laws/enforcement), I'd definitely recommend a windshield strip of tint at the top if you haven't already, It's pretty bright in your cabin, do you have any other window tint?
qcon
Huntsville, AL
I’ve got 20% on the front windows and sunroof. Nothing on the windshield. My screen still gets washed out frequently enough that it’s annoying.
Wolfbraid
Winston Salem, NC
My windshield is 3M 70% and it makes a huge difference but isn't that noticeable from the outside.
I can't get away with that in NC, might try something really light in ceramic just for the heat savings. Although I might wait till after winter, still have OEM glass, I'm betting it'll break this winter sometime.
on a side note Hey which window vents are those? I've been looking for the slim versions just don't know the model.
Edit: I see you are in NC as well, still don't think I could get away with a dark tint up front... I'm in the triad as well, do you recommend anywhere for the ceramic tint? I have to get the front two doors done again as well(bought used with a couple of nicks in the tint)
M3kanic
I have them as well. I love them. Although they hit the glass when you slam the door and people have reported that they also will hit the glass when they are driving fast.
Auto Ventshade 894007 Low Profile Dark Smoke Ventvisor Side Window Deflector, 4-Piece Set for 2007-2013 Silverado & Sierra 1500, 2007-2014 Silverado & Sierra 2500HD-3500HD with Crew Cab, 2007-2014 Yukon XL & Suburban, 2007-2013 Avalanche https://www.amazon.com/dp/B002SE1G3Q/ref=cm_sw_r_cp_apa_i_Q-L3BbKEWP8NY
kbuskill
NE. FL.
70% is effectively clear... if you measured your UN-tinted front door glass with a VLT/tint meter it will measure out at around 70%... just FYI
I have the 70% ceramic on the windshield of my Burb with a 8" 5% strip at the top and 18% on the front doors to match the factory rear tint.
It is hot in FL and the tint makes a noticeable difference.
Wolfbraid
Winston Salem, NC
Yes, I know 70% is lite, but I'm after the thermal benefit more than anything else.
Oh I know FL... We lived there 7 years, our last car was 20% all around, with a big strip on the front.
93blkongreenpro
70% is not noticable. I've had it inspected twice by the dealership, no issues.
I recommend Sound Solutions off Wendover Ave in Greensboro. Good work. Good prices.
Sent from my SM-N950U using Tapatalk
CHOO CHOO
BackPagePhil
Manheim, Pa
Would there be a difference between the Tahoe/Yukon and the suburban/Yukon XL window visors? I don't see why there would be
HiHoeSilver
Away!
Chicago
shouldn't be, just the rear door glass is different on the bottom
They are different. I grabbed a set from another member off an XL not even thinking about it. Do not fit the tahoe. They are too long.
CHOO CHOO
BackPagePhil
Manheim, Pa
Well that sucks for me since I ordered the first link......
I still have time to cancel it on Amazon, but I also got a used/like new set(damaged PKG) for $28 shipped so I might just keep it and see if I can modify the rear ones
Phlipnstik
