dszx13
This came today. Now to decide if I want to dump it or run it out the back with a tip
Sent from my SM-G935V using Tapatalk
ScottyBoy
Shreveport, La
This came in today for when I install the e-fans just need an Autocal and I’m good to go.
I thought about putting one of those in mine, but it's useless unless you remove that rear corner fender brace. I did just end up leaving mine off, and when/if I need to access the fan relays or fuses, it's just as easy to just pop the whole entire shroud off. But then again, leaving that fender brace off, perhaps that is why my fender bent so easily in the minor collision I had last week. I dunno.....
95escahoe
I hear you there, if I ever need to gain access I’ll most likely have to remove that brace but I just don’t want to be popping that plastic cover off an on if I ever have any issues, cause it’s only plastic and might not seat correctly if removed a lot
ScottyBoy
Shreveport, La
Worked on it a little more this afternoon when I got home. Finished getting the rest of the mangled parts of the front, and I repainted the AC condenser. Still gathering parts too, need to getga hood and drivets side fender, but I have a HD hood lined up. Thank God the AC condenser wasn't damaged in the collision, that would be a PITA to replace that and recharge the system. Going to Home Depot now to get some aluminum straps to make some brackets to fit this new big ass transmission cooler on here. It's no Tru-cool, but it's more than three times the size of the tiny OEM cooler. Its a Hayden 679, and it was actually CHEAPER than a replacement factory sized trans cooler.
Bombsquad85
Northern VA
Worked on it a little more this afternoon when I got home. Finished getting the rest of the mangled parts of the front, and I repainted the AC condenser. Still gathering parts too, need to getga hood and drivets side fender, but I have a HD hood lined up. Thank God the AC condenser wasn't damaged in the collision, that would be a PITA to replace that and recharge the system. Going to Home Depot now to get some aluminum straps to make some brackets to fit this new big ass transmission cooler on here. It's no Tru-cool, but it's more than three times the size of the tiny OEM cooler. Its a Hayden 679, and it was actually CHEAPER than a replacement factory sized trans cooler. View attachment 207748 View attachment 207749
Could you do a write up on the install of the cooler? I wouldn't mind upgrading mine in the future.
Korbin_A
