2013 Yahoe SSV trailer wiring
Hal96Tahoe
Bucks Count, PA
BTW I believe the DIC only displays Trailer connected info if you have the factory installed brake controller.
Also, TOW/HAUL is intended to change the transmission programming to accommodate the extra load. Towing in "normal" mode can damage your transmission
Ebay Mike
Detroit MI
Dumb move by GM. They made towing package and factory brake controller TWO SEPARATE OPTIONS....AND....THERE IS NO FACTORY CONTROLLER RETROFIT KIT. You have to buy an aftermarket brake comtroller (Tekonsha or Curt etc.) and mount and wire it up. GM dealer can provide a Curt unit thru GM
GM did not even provide a plug and play connector under the dash... just "blunt cut" wires. Ran into this issue with my CPO 2013 Yukon
So I can't get a factory controller already mounted in the knee bolster and wire it to the wires that are there? That is kinda nuts.
Mike--Hamilton Chevy
Ebay Mike
Detroit MI
Good information that I was completely unaware of! Thanks.
Hal96Tahoe
Bucks Count, PA
Agreed! I have discussed with Service Mgr. and salesperson at GM dealership where I bought my Yukon as well as my 2004 Astro Van. They can't help beyond installing a Curt aftermarket unit supplied by GM PARTS Central. Apparently there is additional wiring and maybe a firmware update to DIC when the factory bolster mounted brake controller is installed. Frustrating and not an owner friendly decision by GM.
Ebay Mike
Detroit MI
Well that really sucks. Why does GM have to make everything so dang hard to upgrade using Factory Parts? Not owner friendly at all.
2011SSVHOE
I'm an egual oportunity offender
The Heart of The Triad, North Carolina
Yep, it really is messed up. Sell a towing package as a whole not piecemeal. I would almost bet that if the Tahoe didn't come from the factory with a trailer hitch, those idiots would build you a truck with a brake controller with no hitch if you punched in the right option codes. Kinda like back in the late seventies I seen a brand new Buick Light blue with a green interior, a fat finger special.
Finish the job GM make it a complete package.
Ron C
Ron C
Los Alamos, NM
No it also has the railer gain settings, it actually jumps to it after the "trailer connected" msg
Ron
Ebay Mike
Detroit MI
these are the trailer RPOs that I found in my vehicle:
JL1: CONTROL,INTEGRATED TRAILER BRAKE
VR4: TRAILER HITCH(WEIGHT DISTRIBUTING PLATFORM)
Ron
Ok I have both of those and I also have :
Z82: Trailering Package (Special) Reese Type Hitch
So if I have JL1 does that mean I am already wired for the brake control in the knee bolster or does it mean something else?
Ron C
Ron C
Los Alamos, NM
Well, the JL1 is the trailer brake "system", mybest bet is that you should see the gain settings in the DIC
The Z82, my best bet is, that that is just a different style hitch.
You don't see the "manual" brake setting control? it is a "slider" with a + and a - button, plus a button that makes the DIC menu jump to the "trailer gain page"
Ron
Ebay Mike
Detroit MI
Ron
I don't see the slider in the knee bolster because I do not have it. That is why I am trying to figure out if I can get a bolster with it and plug it in or not? It makes no sense to me at all that I get the factory hitch but no brake controller????
Ron C
Ron C
Los Alamos, NM
I don't know if the wiring is there then, and the slider-button thing is just another RPO. Else, get one from a salvage yard?
These switches look pretty simple, so many of them should work (theu also were used in silverados etc)
Ron
johnsonwillie199
