Wambliokiye
Reno, NV
Looks like a rubber.....would be better if it said ‘catch all’....:)
To the touch it feels like rubber. I chuckled when i opened it, once it was wet and sanding started! that lil block ripped it up. The brown milky stuff is road grime and who know what else. So you just sand till no more muck. Hoes down the light, dry and wipe. Hell $9 VS $340 was a great deal. I also got the wipe new tire care. Living in the desert tires dont shine for more than a few days. Wanna see if it really last 6 month. Show you guys when i am done and ill update in 6 months! If i remember.
Wambliokiye
Reno, NV
Mine has what looks like a clear coat coming off. When it cools off we have the Meguiar's kit to redo the GMC's and Kia's headlamps. Might just clear coat them afterwards but haven't looked into what to use yet.
Ima check around the rust oleum site and see what they used to seal it. The lil wipe was soaked when i opened it, i let it dry out and the wipe was rock hard.
Wambliokiye
Reno, NV
Wow! It is a noticeable increase. Sure after the tube is in it will respond better. So i got a longer tube so it fills in better in the stock filter location. Give me your thoughts on this!!!! You know the lil air scoops? I wanna cut out the side fender and install a thin sleek scoop that is actually functional and box up the filter so i am actually drawing colder air that the air inside the wheel well. 20180817_153428.jpg
Any thoughts?
93blkongreenpro
New edelbrock filter! Still waiting on the tube.View attachment 205417
Doubtful on the 470 horses.View attachment 205418
Wow! It is a noticeable increase. Sure after the tube is in it will respond better. So i got a longer tube so it fills in better in the stock filter location. Give me your thoughts on this!!!! You know the lil air scoops? I wanna cut out the side fender and install a thin sleek scoop that is actually functional and box up the filter so i am actually drawing colder air that the air inside the wheel well. View attachment 205424
Any thoughts?
Why not just draw it from the bottom under the bumper/behind the tow hooks?
Sent from my SM-N950U using Tapatalk
Any thoughts?
The OEM setup already does exactly this, and without gaudy fender vents. The stock air box, filter and all flow more air than the engine can ingest at WOT at RPM redline while sufficiently filtering it. If you wanna do a little something, get a scoop from an older TBI car at the salvage yard and use it as a duct to bring a harder air charge into the stock box from outside. Just consider rain and water puddles when placing the scoop.
If you're dead-set on doing as you planned, you're gonna need bigger or more scoops. Look at the size of your throttle body- the hole or holes in the fender need to be about that size or bigger.
Any thoughts?
that means it is good for use with up to 470hp systems, not 470hp gain ;)
Luggz
