00'BlueSteel
Carolina
I'm pretty sure they changed the gap on the 99-02's to .040 also in a TSB. I've been running .040 in my 02 forever. And the iridiums will come at .040; double check them but they aren't supposed to be re-gapped or they'll prolly get damaged.
A little late to the party but I found it. I did notice this is for the iridium plugs and I am running the platinums at the moment. I think 0.060 is right for my truck if I have platinums and 0.040 for iridium?
Document ID# 1396703
Subject: Information on New Spark Plugs and Gapping #03-06-04-060 - (10/24/2003)
Models:
2004 Buick Ranier
2002-2004 Cadillac Escalade, Escalade EXT
2003-2004 Cadillac Escalade ESV
2004 Cadillac CTS-V
1997-2004 Chevrolet Corvette
1998-2002 Chevrolet Camaro
1999-2004 Chevrolet Silverado
2000-2004 Chevrolet Suburban, Tahoe
2002-2004 Chevrolet Avalanche
2003-2004 Chevrolet Express, TrailBlazer
1999-2004 GMC Sierra
2000-2004 GMC Yukon, Yukon XL
2001-2004 GMC Yukon Denali, Yukon XL Denali
2002-2004 GMC Sierra Denali
2003-2004 GMC Envoy XL
1998-2002 Pontiac Firebird
2004 Pontiac GTO
2003-2004 Hummer H2
with 4.8L, 5.3L, 5.7L or 6.0L V-8 Engine (VINs V, P, T, Z, G, S, N, U -- RPOs LR4, LM4, LM7, L59, LS1, LS6, LQ9, LQ4)
A new spark plug has been released for use in the above vehicles. The new spark plug has an Iridium tip instead of the current Platinum tip. Due to the different tip design, the gap of the spark plug has also changed. The new spark plug, P/N 12571164 with AC Delco P/N 41-985, is gapped to 1.01mm (0.040 inches) when the spark plug is made. The spark plug gap is set during manufacturing and should not be changed or damage to the spark plug may result. Any new spark plug found to not be properly gapped should not be used.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© Copyright General Motors Corporation. All Rights Reserved.
Had to stop mid install to replace broken window regulator for right rear. Finally got the front seats done..working on the rear seats now..
anyone know how to break down the center armrest/cup holder in the rear please chime in before I rip it apart..
Nice!
Models:
2004 Buick Ranier
2004 Cadillac CTS-V
2004 Pontiac GTO
2003-2004 Hummer H2
I’ve been running .040 forever with all my plugs, even before the blower. I just changed to a colder plug( NGK TR6). I saw that tsb too but I swear I saw somewhere to run .040 on all plugs. Probably ok either way but just check the iridium ones, don’t re-gap them. If they’re not right return them.
Pachanga02
Ny
Haven’t been on here as much and just wanted to add something. I was in Florida and got back yesterday morning. Drove from NY -Florida and back 2600 miles and averaged between 15&17 mpg on each tank. I did an oil change, air filter, fuel filter cleaned the maf and throttle body. Great time with family and a great time in the truck.
Cinycreech
So with other items on the truck trumping the priority of replacing the rusted front and rear bumpers. I decided to picking up some bed liner spray with my first intentions of just spraying the body moldings. After some consideration I figured to just spray the bumpers as well, since I plan on replacing them in the near future anyways. Turned out okay, nothing special, now I don't have to stare at the rust. Ended up running out of spray before I could completely finish the rear bumper, had somewhere to be
were
HiHoeSilver
Away!
Chicago
View attachment 205177 View attachment 205179 View attachment 205180 were
Which bedliner did you use and how did it go on for you? Any adhesion promoter or special prep?
bottomline2000
Dallas, TX
Sorry buddy, I don't.
The front seats look great. Once I replaced those rubber tabs in the 2nd row drop down console, I pulled that upper piece off--the top of the cup holder--just pry it off. That's as far as I went, but there MIGHT be some screws under there that might get you where you need to be. Lmk how it goes.
Thanks Tony. Thats what I was thinking. I pryed them up a little but they were creaking pretty bad. I'll give it a go and see what happens. I'm ready to see this done..already feels like a new truck lol..
06JET
Wisconsin
Changed out my trans oil cooler lines and connectors yesterday. Broke the oil cooler so had to get a new one but all in all not to difficult. Every time I work on this thing I am glad I installed the 3" body lift. Makes everything easier to get to.
Old
New
brian.roberts.1293
Durham NC
Got the hids in and halos and leds wired up too. Had to do a little filing on the projector housing for the hid to fit on one side.but turned out pretty good. Got to drive it two minutes up the road for test drive everything worked well.
Sent from my SM-G965U using Tapatalk
It'll creak like a mofo, just do it!:D
Scottydoggs
NJ
got out of work early due to rain, so i decided to wash it fast drive home slow, dry it and then clay bar and then used adams h2o guard iirc. (parked under my building) my god the paint looks wet, so smooth to the touch.
shame i had to go and park it out side where its gonna rain again 100% lol
back out waiting for the rain.
Bombsquad85
Northern VA
I wish my paint shined like that haha. I have spots on my hood and roof with no clear
Scottydoggs
NJ
thanks, my rockers are trashed tho, should be replaced over winter i hope. or ill trade up. undecided.
theres a area on the hood thats got a faded look to it, never seen it before. very faint fading.
i was up at my brothers sat, hes like lets do your hood ill show you how good this stuff works, after we were done i was amazed at the shine, but. im like damn it man you ruined my paint job, now i can see all the defects, i got 3 acorn dents i never saw before and that faded area. the roof has 2 areas of missing paint. those im gonna spray up and not care what it really looks like cause no one can see it.
hard to see but along that line where the light is, that little area is a little pooched. you really need to look to see it tho.
TheAutumnWind
Anyon want to recommend some good brake pads? I intend to do the nnbs front brakes upgrade and my current pad though fairly quiet do not perform great.
I dont mind dust but the wife cannot stand brake noise.
Thanks!
95escahoe
Thanks!
Wagner is pretty good, can get good deals on Amazon
Escalade2007
