brian.roberts.1293
Durham NC
Why not sand, buff and reclear the old lights?
So how hard would that be? I've never done much paint work or anything. But if be willing to try. Also someone put a set of depos on here. Is the light from the projectors that much better than a stock style light with a hid?
Sent from my SM-G965U using Tapatalk
brian.roberts.1293
Durham NC
Also what are the best and brightest LED bulbs out there for the low beam especially? Been looking around but there are so many cheap ones out there.
MINIz guy
Sold her after 1 year 2 months and 16k miles. Was a good ride but I want to save up for a new vehicle with a warranty.
Some guys dry sand while others wet sand. All you want to do us just get all of the clear coat off, you don't need to be aggressive. Once you've sanded, buff them with 3M plastic polish, then find a good uv protective clear coat and spray them. Easy.
brian.roberts.1293
Durham NC
What grit sandpaper would you suggest ?
Scottydoggs
NJ
2500 or 3000 grit. you dont want any thing to aggressive, even 2500 is going to remove the clear pretty fast. with a light pressure, just let the paper slide over the paint.
you dont want to sand it like its wood, and stay off the edges or you can cut through the paint, be very light when sanding on those areas.
id not remove all the clear coat thats still stuck, the sanding is only for a mechanical bite for the clear coat to stick on there. any of the light scuffing you see the new clear coat will cover up like it was never there.
id search youtube for some how to vids, what i did when i first took on a larger paint job, aka both bumpers off my regal. theres all sorts of tricks you can do along the way to make life easier on your self as far as taping things off and also gain the confidence to just dive in. cause its really easy work, just takes some time.
He wants to do his headlights. I agree, not too abrasive.
Scottydoggs
NJ
good lord got mixed up with another thread lol yeah soame rules apply there, only you can work your way from 800 to 1000 and finer to really cut off the crap plastic. then clear coat em.
did my regals like 2 times, then when they hazed over the last time i went and bought new headlights. i fought the haze and the haze won lol
i never did clear them. but they looked damn good when i was done. sanding and then compound with a dual action buffer.
iirc this was the second time cutting and buffing them. left one is done, right one is not.
mdnitedrftr
CT
Here's a little preview.
4 coats.
Don't mind the garage floor...didn't anticipate THAT MUCH drippage.
I think I'm going to pick up one can of the spray on version just to hit some of the spots underneath that the brushes couldn't really get to, and also for touch ups.
On another note, can anyone recommend a good garage floor cleaner?
brian.roberts.1293
Durham NC
For the guys that have the projector headlights. I was looking at the depo set someone tagged in here. I have a question I have 6k lights in the front end. What kind of light (ie 5k 6k 8k) comes stock in these projector headlights? Can I change over to a nice LED bulb in them?
ArcticYukon
The White Yuke has been superseded by a Red Hoe
Dry Ridge, KY
OEM halogen bulbs are about 4300-5000k light. 6000k is the typical color temp range for LEDs which, is more of just a pure white. No yellow or blue tones to it. If you still prefer though, I'm sure you can find a "warmer" color temperature LED bulb in 4300 or 5000k.
PG01
Up here to the right
4 coats.
Muriatic acid
05Single
afraid of the dark
Finally got time to finish rebuilding my ABS module. I re-soldered all the solder joints and put new heat transfer paste, then scrape all the old silicone glue off and then glued it back together with red RTV silicone. The tricky part is cutting this sucker open! View attachment 204221 View attachment 204222 View attachment 204223 View attachment 204224 View attachment 204225
You're a mad man, and because of that you saved tons of money . Nice work ! Maybe a seperate write up, if I recall this is a common issue with these years right ?
05Single
afraid of the dark
They'll come with cheapy Chinese halogen bulbs. Might still be same bulb 9006 , @Fosscore will know. And 6000k will have a tiny hint of blue. 5000k will be purest white. Try not to use led bulbs in projectors, always hids. I know from personal experience
Merch619
