Massfloefi
Received another transmission cooler line today.
Anyone else see a problem with shipping a aluminum line without a box?
ScottyBoy
Shreveport, La
@Tonyrodz , in your opinion what should I do about this seat. It's pissing me off that it looks like this. It's been cracking on the side for a few years now, and now it's split wide open right above the seat control switch.
@Tonyrodz , in your opinion what should I do about this seat. It's pissing me off that it looks like this. It's been cracking on the side for a few years now, and now it's split wide open right above the seat control switch. View attachment 203661 View attachment 203662
@ScottyBoy That side piece is vinyl. If you don't want to replace the entire lower seat cover, or have an upholsterer replace that 1 piece, the only decent way would be to sew it. I hope your sewing skills are up to par. But please, whatever you do, DON'T USE DUCT TAPE!
95escahoe
Dropped it off at the shop who did it before. Says it looks like a new spot, but he's not positive yet. I guess we'll see tomorrow.
Damn that sux, hopefully it’s just a different line or something simple
Scottydoggs
NJ
i got a friend who changed his tranny lines on a grand prix and it kept leaking from the fitting, turns out the fitting on the trans also needs to be changed, the new lines end was longer. something worth looking into if its leaking at the quick connect.
95escahoe
X2 on this could be as simple as that, when I replaced the tranny & oil cooler lines on mine I replaced all the fittings
I hope it's something that easy.
bottomline2000
Dallas, TX
Should have used middle finger for a true shadow effect. Wth is so hard about getting those lines right. Maybe look into some stainless braided lines with proper fittings? Mine have been solid since I put the trans in. U put a lot of time into stopping this leak.
Too much time. I'm just totally disgusted right now. It was a brand new Dorman line. I was going to buy a new oem GM line and have them put it on, but you know how alot of mechanics won't use customer supplied parts. I guess we shall see.....to be con't.
Drewphil
