Or a few layers of duct tape on the part of the center caps that go in the wheels. Make 'em a little thicker.
I actually had thought of that, but I wasn't sure if they'd stay in place on the road, as they wouldn't be able to snap into place. Inertia is a beyotch. There's tangs behind the center caps itself, I wish they'd snap in there somehow, that would solve all my problems.
Or double sided 3m tape.
But best solution is sell these and the winter 17s and run oem silver finish 20s all year :waytogo:
BLASPHEMY!! Nah.
Thats good for a date but not for a vehicle my friend. Didn't you learn anything growing up?
Nope, I had a misguided childhood.
bottomline2000
Dallas, TX
I'm not sure if I'd trust the dip enough to keep them in place while driving. They might just get flung out. Thx tho for the input.
If you want cheap you can use some E6000 to hold them in place and then plastidip over it. Its hobby grade adhesive that's sold at Home Depot and other hardware stores. The stuff is solid when it dries and remains flexible but is not likely to come out.
My wheels have the model name on the back of them. Maybe you can find the original caps online..
05Single
afraid of the dark
Yes sir, every wheel has a model number or name stamped on the back.
PG01
Up here to the right
@Tonyrodz .. pop them in, run a few beads of silicone around the tangs on the inside closer to wheel then plastidip over the otside and you should be good. Or try to fid a large enough snap ring. Like from an old school manual 4wd hub.. or the like
Mrsteef
Finished up my taillights with the litte resistor for the blinkers and put in the reverse bulbs
I've actually used that before, it's good stuff. I've looked all over those rims are there isn't anything on them, sux. Talk about cheapie!
@Tonyrodz .. pop them in, run a few beads of silicone around the tangs on the inside closer to wheel then plastidip over the otside and you should be good. Or try to fid a large enough snap ring. Like from an old school manual 4wd hub.. or the likeView attachment 200976
I'll give it a shot. Hopefully this weekend I'll have time--if it doesn't rain again.
Bombsquad85
Northern VA
How bout a small electric sander or die cast angle grinder with sanding pads. ?
Using both I have my angle grinder with an 60 and 80 grit pad then a palm sander with 120 and then primer but I have to hand sand the right areas which have the most corrosion
hulk66049
Decided recently I needed to start doing some cleanup on my Yukon XL. I'm not sure why, but there's so much inconsistency. For instance, 3 of the 4 doors have a rain guard, 1 of 2 mudflaps, 2 of 4 doors have edging, etc...
So...I removed the door edging from the 2 doors and cleaned up the remaining residue and removed the single mud flap. I'm leaving the rain guards until I get replacements. I also pulled one of the tail lights and gave it a good sanding/buffing as it looked like it had been clear coated and was flaking off (still need to do the other tail light). Removed the rear upper vent appliques, gave them a good scrubbing and buffed them out as they were looking pretty faded.
Just working through little things here and there to help it present better.
MINIz guy
Like hulk66049, I need to get my Tahoe more presentable.
I did a quick wash and spray wax tonight as it sat under a tree at my parents house for over a month. It still needs a proper detail, but I'm always busy and don't have time to maintain any of my cars. One day this summer I'll have a free weekend to catch up...
ArcticYukon
The White Yuke has been superseded by a Red Hoe
Dry Ridge, KY
Fiddled around with the hood latch trying to pull the center of the hood down to eliminate the gap between the hood and grille... didn't have much luck. In the process though, I noticed the headlights were pointed at the freakin' SKY!
Aimed them down to where they were flush with the grille on both axis and brought my e-torx socket with me to work so I could correctly aim them on my break.
Mush mo betta!
Drewphil
