Drok
Cold place in the north
YEP, more likely to smell it from outside especially just after a drive
Well no leak but my dad figured what it probably is. (Older generation wisdom) he knew the smell right off from old drum brake sticking and only one wheel was really hot to the touch. So i hit the ebrake and heard a clunk noise. Drove home and no smell. Ill be getting it checked on monday.
Idk whats going on. The trip to work i got out of the truck and could smell something like hot or burning electronics like a abused speaker. The smell went away fast and couldn’t locate it. I then drove home after work and the same thing happened.
I went around to all the speakers and none of them had any burnt or hot smell. I even went to smell inder the hood cause i have led lights. I also smelled in by the fuzes and nothing.
The only think ive had done lately is an oil change and ball joint done.
Im at a loss haha.
Did you say the smell is outside or inside?
edit: didn't see your last post. Hope it was just the e-brake sticking.
XEALOT
Northern MI
Used a Flex polisher to Buff, polish, and then seal the paint on the whole truck. Tried out this Pro Car product called "Poly Gard". I've used it on newer cars, and it looks great and lasts a long time. It's polymer based, not wax based, but you apply it just as you would a wax. As always, the pictures don't do it justice, but the results were amazing. My rig has a gloss and shine that now looks even better than newer cars that it sits next to in the parking lot. :)
Fosscore
Used a Flex polisher to Buff, polish, and then seal the paint on the whole truck. Tried out this Pro Car product called "Poly Gard". Iv'e used it on newer cars, and it looks great and lasts a long time. It's polymer based, not wax based, but you apply it just as you would a wax. As always, the pictures don't do it justice, but the results were amazing. My rig has a gloss and shine that now looks even better than newer cars that it sits next to in the parking lot. :)
View attachment 199312 View attachment 199313 View attachment 199314 View attachment 199315
Looks great.
PG01
Up here to the right
So much shine
Chuck_Finley
Towed my boat 25 or so miles on the interstate down to its marina for the summer, it towed really well considering I'm used to borrowing a friends' F350. It's only 3500# and although I could feel it, the transmission temp kept under 170*, tow mode worked great to keep the RPM's up and I had no issues on the wet ramp.
St. Louis
I have a tractor/snowblower that I never use, so I loaded it up and towed it about an hour away to turn it into a 4 wheeler that I'll never use. View attachment 199332 View attachment 199333
Should've mowed your grass before getting rid of the mower.... j/j lol
What year is your Denali? Looks just like my 2011
2001 Yukon SLT
2011 Yukon Denali
JPatton
West Chester
2001 Yukon SLT
2011 Yukon Denali
It's a 2008 so it's the second year of this body style. I bought it recently and couldn't believe that it's 10 years old.
aflumb
Las Vegas
After a little over a year of using my air compressor to fill the Trail Blazer SS rear airbags, I finally installed an airlift compressor to be able to fill from the inside at the push of a button.
moto
