Rear seat removed. Loss keyless entry.
wolf1340
Took out my third row seat(2017). Now my keyless entry won’t work. Anybody else have this issue? Is there a fix for it? If not I’ll try taking the electronics from the seat and plugging it back in. And see what that does and go from there.
I don't think removing your seat's would have even a smidge of anything to do with keyless entry.
wolf1340
wolf1340
You wouldn’t think so. But, it only happened as soon as I removed it. And there is a significant sized module under the seat.
wolf1340
wolf1340
Once I have some free time I’ll try to separate the module from the seat and plugging it. See what happens.
the seat doesn't just pull out for more storage room? my 2012 seats all come out with a handle except the front seats
wolf1340
wolf1340
No unfortunately they don’t. Bolted to floor. And, don’t lay flat when folded down. ****** design.
hmm I poked around on another forum about taking out the 3rd row seats and no one mentioned it doing anything to the keyless entry, I presume yours must have the power fold? if so the electronics are probably just to power the seat motors. I still don't think it has anything to do with keyless entry, the antenna should be up front inside a quarter panel so I don't think there going to be related at all, one way to verify I guess is to just set the seat back in there and plug it in but I think it may just be a coincidence.
Maybe the kind of airbags back there prevent them from being removed. It has been my experience that those fold flat seat are much less comfortable for adults. A flat floor comes with many other trade offs.
Kpwweb
The module is just for power fold. I took my seat out and did not affect keyless entry AT ALL.
Ct Pirate
Senior Member
I soo want to take out that third row the tilted cargo area is driving me NUTS!!!! How bad was the mod?
dbbd1
And the mini storage area.
Alas, the wifey says no. "You never know when we might need the room" (yes, I DO know...)
Ct Pirate
Senior Member
I'll over look the option for the two-three times a year I might need it. Hell I'll call them an Uber and the rest of the year be happy every time I open the hatch. And DAM that hatch is low !!!
wolf1340
wolf1340
15 minutes. Remove 7 15mm bolts. Unplug harness. Remove seat. Put bolts back in holes. Then either get a cargo mat or a piece of carpet. Will be missing carpet in a few areas.
Ct Pirate
Senior Member
OH HELL YEAH!!! I'm doing it! I use a weathertech mat anyways.
noob
New Orleans
I wonder how large the trunk will look without the seats in my esv? It’s already pretty large and I only have 1 kid
Ct Pirate
Senior Member
Not sure but I'll know shortly!!! Does anyone else have a before and after pic?
wolf1340
wolf1340
Problem solved. Put seat back in to see if that was the issue. While pugging it in I could hear something hitting floor. Looked under carpet and found a wire unplugged. Looks like it goes to an antenna for the keyless stuff. Looks like a little square box. Plugged it back in and all is good. Took seat back out. I must have unplugged it while pulling on the seat plug in. It’s tied in to the same harness.
34B3538B-4DD1-45D1-BA99-B59D8985BBD1.jpeg EF7FE5B1-E468-471E-BE76-C9132110D459.jpeg 11E00FDD-93A6-441F-855A-18342D727BB9.jpeg
Ct Pirate
Senior Member
AWESOME WOLF!!!! Looks like I know what I'm doing for the next mod!!! Thanks for the pics man NICE!!!!
yesac
OK so got all the bolts unbolted on the third row - but I can't figure out how to unhook the electrical harness. Is there some trick to it? I feel like I'm going to break it.
wolf1340
wolf1340
First to make it easier. I put a 2x6 to hold the seat up. Then get a small screwdriver to undo the clip holding the connections together. It’s just a little clip you got to lift so the connections will come apart.
Durobans
