LanceD's PPV Thread
elsamurai
Today I used my HP tuners to turn off DOD, enhanced some of the engine tune and tightened up the trans tune. Runs much better now
Do you have access to a dyno for tuning, or are you running a wideband?
LanceD
LanceD
AZ
Neither yet. Just got rid of a lot of the torque management stuff, and made power enrichment come on sooner. Haven’t messed with any spark or fuel tables yet.
992dr
Eastern N.C.
Nice, how do you like HP Tuners?
I've been debating for a very looooong time to buy it. My only issue is I don't get along with computers and I'm kind of intimidated by it.
Did you find it to be a simple process to go through and figure out?
I don't have any shops close enough to tune. My old tuner is roughly 3 hours away now and I don't want to haul my Tahoe after every upgrade. I'm going to have to figure it out sooner than later
LanceD
LanceD
AZ
I am too. I have been doing a lot of reading and video watching, there is a lot to learn
992dr
Eastern N.C.
If you could please post your progress as you learn and the steps you made. I know I would appreciate it very much :)
LanceD
LanceD
AZ
So far I have downloaded other people’s tunes and copied some To mine to see what it does. Turned off most torque management, turned off DOD, lowered shift times and increased pressures, made it so the ac turns off above 50% throttle, etc
SWSS
Smashville
Nice work! How aggravating was the bow tie wrap?
LanceD
LanceD
AZ
Used a heat gun but maybe I didn't get it hot enough. It's already peeling in the edges.
LanceD
LanceD
AZ
Gathering parts to do the DOD/VVT delete and got this bump stick to put in.
LanceD
LanceD
AZ
Hitch install. Found out the hard way not to use an impact on the big bolts. Snapped off a welded nut inside and had to torch off the bolt to get it off.
Before
During
After
LanceD
LanceD
AZ
Had some 9006 led headlight bulbs laying around so I figured I'd JB weld them into my reverse light holes. Haha
Drewphil
