Show off your aftermarket wheels !
Shaw520
Personally,.. I think I prefer old school looks with a lot of sidewall, the new look with tall rims and no rubber is just not appealing to me,... plus true off-roaders (not that I am, but like the look) would want plenty of sidewall for protection against rocks ect. Also im not a big fan of ALL black wheels,.. some black mixed with chrome/machined looks w/bead locks are ok. But anyways,.. love to see what you guys are running. The picture below is one set that Im seriously considering.
Jlaughtr
Deming, NM
I went with the Flat Black Pro Comp 7032. I've always been a dark color preferenced person. Chrome and shiny doesn't fit my personality. Went with the OEM Size 17". Only issue I have with these wheels is the center cap only has 2 real screws and I have lost one. 6 "screws" and only 2 are real....dumb
images.ashx
Shaw520
Shaw520
Those look good JLaughtr,.. I think Black looks decent on darker colored vehicles.
So the wheel I posted in my 1st pic list a 0 offset and 4.75" of backspace,... anyone know if this will bring it flush to the outer fender flare,... or how far out past stock ?? TY
Rustynail1978
It will probably be close, depends on the wheel width and the tire width.
Here is a profile I setup for my Sierra a couple years back right after I put my new wheels on. I kept it simple and went 17x9 with 0 offset so I could use my old tires that were brand new, but then decided I needed something a little bigger and went up from the stock 265/70/17 tires to 285/70/17. They fit the wider rims a lot better. Stock wheels on my truck were 17x7.5 with -33 offset.
Shaw520
Shaw520
Here's the package im seriously considering;
Vision Fury 339C - 17"x8.5 w/0 offset Backspacing is 4.75
Cooper Discover AT3 - 305/70/r17
Shaw520
Shaw520
Order is in,.. Mounted, balanced and delivered free to my door,..should see them in 10 days,..hopefully the roads will be cleaned up soon,..
DirtyHoe2002
SE Nebraska
I’ll be getting a new set up here in about a month once I deliver what I currently have to a buyer.
What I have now:
Black Rhino Warlord 20x9 -12mm
with BFGoodrich KO2 35x12.5R20
What I’m getting:
Dropstar 654BM 20x12 -44mm
with Patriot Torque M/T 33x12.5R20
Shaw520
Shaw520
-44's are gonna poke out a good deal,..nice setup :waytogo:
Shaw520
Shaw520
Tires/rims came today,.. I like them but Im getting prepared for some trimming,....With the 0 offset I was hoping for a bit more lip, but when you see the back of the wheel you'll see why the spokescooper 34.jpg
are so far forward, not sure why they do that.
Shaw520
Shaw520
I will not have a chance to install them till Sat,..hopefully. They are just a tad over 3" taller than the 265's currently on there,.. and an 1.75" wider,...it looks like Im gonna be doing some trimming !
MINIz guy
Wow those look really good. I'm interested in seeing how flush they are with the body when you get those installed!
Shaw520
Shaw520
Well according to preliminary measurements, (me and a ruler), looks like theyre going to be at least flush. But I'll be sure and post up some pics once bolted on.
Shaw520
Shaw520
Those get great marks from guys that run them. Good pick. Now LIFT that girl!
I put the 2.5" keys in last night,... and the air-lift bags for the rear arrived in the mail today... with just the keys cranked to about 1/3 she's sitting between 38"-39" in all 4 corners as we speak.... the air bags will ad another inch or two to rear springs. I should have install pictures by the weekend....
This is a pic with just 2.5" keys in front.
Shaw520
Shaw520
Pictures as promised,...tires measure 34x12, 2.5" lift key in front, stock Z71 springs in rear,... had some minor trimming on drivers side front inner fender plastic, trimmed about an inch off the front where it meets the windshield washer reservoir, and a heat gun to the rear of the ds front inner plastic was all it took. These rims are 0 offset and I feel the tires could come out another inch or so. I may ad 1" spacers. All for corners are sitting at 39" fender height, im defiantly going up another inch in the rear..... air-lift bags not installed yet. So on previous trucks Ive always ran two air lines T'ed into one shrader valve, but doing some reading on the issue, it seems that load shift and air transfer is a very real thing, its a hard concept to fathom because you would think 30 psi is 30 psi no matter what,...opinions?
massivespl
I'm not mean, I'm honest.
Michigan
View attachment 196032 View attachment 196033 View attachment 196034 View attachment 196035 View attachment 196036 View attachment 196032 View attachment 196033 View attachment 196034
These were 20x10 with 0offset
The offset isn’t going to make it have a lip on the rim. The width of the rim matter. Can’t have a lip a on 8.5wide wheel... need at least a 10”wide wheel to get a 3”+lip.
Shaw520
Shaw520
Actually, if you go back and look at the first pic I posted, the wheels showed a decent lip, the spokes where basically centered in the wheel,...but when the wheel arrived the spokes were actually negative offset and the back where it mates to hub was built up about 3" (see photo of actual back side of wheel). So that was a bit deceiving for me, but the wheels were mail ordered so not much I can do know.
Shaw520
Shaw520
If the wheel is advertised as (0) offset, one would think that the spokes would be centered,...but instead they built up the back of the wheel about 3"
massivespl
Michigan
The first pic is a stock picture of like 10wide or 12wide wheel. U can’t go by a stock internet photo. I can tell by looking at the photo it’s not a 8.5”wide wheel. Yes Very deceiving if u don’t know wheel well. The custom offset videos on YouTube have a lot of good information about getting the right wheels for your truck
BadDaddy2003
