Dream Engine Swap/Build
Onebad1983
Resident Country Dumbass
This thread is for what you would drop into or build for your vehicle. Anything goes! Include full specs please!
Adding a supercharger would be fun but so would building a stroker motor out of my LC9. I'd put in Darton wet sleeves and run a square bore motor, 4.0 bore x 4.0 stroke for a 402 cubic inch motor. Run the stock 243 heads and a mild camshaft and shoot for 500 RWHP. Add a supercharger and shoot for 650 RWHP which would be enough to run 112-113 through the traps in the 1/4 mile. Would use an AXN 14-Bolt Rear and 6L90E transmission.
Another idea is converting over to an LBZ Duramax and using the 9.5" 14-Bolt axles (drop in) and 6L90E or the Allison.
In the end, I'd probably enjoy just making a stroker motor out of my LC9 and beefing up the drivetrain to handle it over the long haul.
It would be most economical to drop in a massaged L9H compared to the other ideas. But not sure my brain would let me do that.
Onebad1983
Onebad1983
True that man
bottomline2000
Dallas, TX
Here's a start..
That twin turbo setup was done nicely but not conducive to getting up on boost fast with those long pipes. It might help with traction though. I'd go with a single turbocharger, such as a 60-1 or a little larger for a 5.3 and lay it out to match as close as possible the Buick GN LC2.
bottomline2000
Dallas, TX
I guess you didn't notice the lsa blower sitting in the middle..instant boost!
Sent from my SAMSUNG-SM-G900A using Tapatalk
I wasn't sure what that was. I would call that a large hand grenade. A handsome one, well constructed, but a grenade nonetheless.
Turbo-Supercharging was used extensively during WW2 to allow aircraft to reach higher altitudes. Of course it shortened engine life.
FrankU
Babylon New York
That turbo/boost set up has got a lotta WOW factor in it !!!!
I'm thinking take the easy way out with a L9H and a Maggie. And the automatic 80/90 transmission won't hold that down.
scottd
