01 Suburban non-bose factory amp?
Creed422
Ive tried 2 other used stock amps and out of three amps none are working. Hard to believe all 3 are bad but it is a possibility.
Ive checked the amp fuse under the hood which is good. What else is there to check?
Possible head unit bad? The radio does work, it just has no base.
Creed422
Creed422
anyone have any ideas?
Any suggestions on what to check next would be appreciated.
ScottyBoy
Shreveport, La
Do you have any sound at all coming from the speakers? Or no sound at all, basically like the radio is off??
Creed422
Creed422
I have sound just no bass. The sub in the back isnt working at all.
Creed422
Creed422
The factory amp is on if the door speakers are on. Are you 100% sure that the subwoofer is not blown?
Not really sure on if its blown or not. I dont have a spare to check it. Just know its all trebble throughout the whole vehicle.
I just purchased this 01 Suburban lil over a month ago and have been replacing broken or damaged parts here and there.
1999hoe
aka HOVERHOE
Massachoochoosetts
When i replaced my sub it was completely desintegrated and had zero bass i replaced it with a 4 ohm sub which i had to connect both sides plus to plus negative to negative and make it a 2 ohm sub it now thumps pretty damn good for a stock amp i am now in need of th crossover bypass harness but am looking for one rather than build it
Nickfromga
What sub did you end up going with? I am honestly looking for just a cheap replacement for the stock location.
Thanks
Creed422
Creed422
Update: turns out it was the sub. Totally deteriorated. Found a Kicker 8" 2 ohm shallow mount sub on that Letgo app not far from me for $65 brand new. Best buy wants $120 so I practically stole this thing.
Now hears another question.. What would be better for door speakers? 2 ways or 3 ways? Found some Kenwood 2 ways and some Pioneer 2 ways and 3 ways. Cant decide on which would sound nicer or be better.
Im not lookin to spend a shit ton of $$ just some decent replacements.
Z28TWITCH
Aftermarket speakers with stock radio and amp?....get more enjoyment out of a burger from McDonalds.
bgdevor53
