LED Taillights How to on Barn door models
YukonXL04
YukonXL04
The Riverboat
Arlington, TX
I think the newer version of these lights have it built in. Mine have resistors built in on the turn signal, but not the brake lights.
If I recall though I remember seeing a thread about newer version of these lights not needing any resistors at all.
So 5 years later still work great btw lol...
And yes I did have to add a resistor to the brake lights to keep cruise control. It was a month or 2 after doing the write up that I realized my cruise wasn't working.
And pictures work for me. What about yall?
Creed422
Thanks for the quick reply! Were there any major gaps when installing these lights or did everything fit snug once you cut away what was needed?
When I was looking for a set these were the exact lights I was leaning towards, then saw they were non-barndoor, then came across your post. Oh and yeah your pics are loading but didnt see one with a resistor. Where did you install it and what type of reisitor was it?
YukonXL04
YukonXL04
The Riverboat
Arlington, TX
Yea I never did add pictures of it. Just a simple 50w load resistor. Look on Amazon. They are like 5-10 bucks. I installed it behind one of the tail lights.
I think they fit better than stock. No gaps at all. Ask cattivo if his needed resistors or not. The new ones may not even need them anymore
silverfox103
Littleton NH & St Simons Island GA
Goodmorning Shawn
As you know, not much available for aftermarket tail lights. Searched and came across your "tail light how to".
The tail lights you used, coincidentally are the ones I like. Until, I found these, which I like a little bit more, but not much.
https://www.ebay.com/itm/DARK-CHERR...e=STRK:MEBIDX:IT&_trksid=p2060353.m1438.l2649
Can you take a look at and see what you think. The backup light is in a different location than your lights, which may create a problem.
Picked up the Yukon down in GA, almost 2 years ago where we are snowbirds. Great truck! Been fixing the piddly little stuff, that makes the difference. Got 95% of them done.
Thanks
Tom
Littleton NH
YukonXL04
YukonXL04
The Riverboat
Arlington, TX
Goodmorning Shawn
https://www.ebay.com/itm/DARK-CHERRY-RED-2000-2006-GMC-Yukon-XL-Tahoe-Suburban-C-Shape-LED-Tail-Lights/172326182020?ssPageName=STRK:MEBIDX:IT&_trksid=p2060353.m1438.l2649
Thanks
Tom
Littleton NH
Hey Tom,
Unfortunately those lights wont work. The reverse light will hit the door hinge. You have to fine some where there is a reflector down low and make clearance
ClassicChevyMann
It’s 2021. I’ve successfully installed these on my 2000 Suburban. No modification, direct bolt on and plug and play. All I had to purchase additionally was a set of 4157 LED bulbs for backup lights and was all set! :https://www.ebay.com/itm/201658122525. Now my rig is updated and looks amazing.
E8D528B3-EF19-4250-8CB0-28760418A366.jpeg B2B46F5F-3A83-435A-80E9-57557F0299ED.jpeg
Project Denali
This is sharp, had these taillights on my hatch yukon. Very nice work and post!
YukonXL04
YukonXL04
The Riverboat
Arlington, TX
Congrats on finding a bolt on set. There were others that could fit without any mods, but I didn't care for the style. I liked the clean look of the ones I used.
I sold that yukon about a year ago, the tail lights worked and looked great still.
Mousse1984
Hey, This is my first how to so take it easy on me.
I have searched all over to find a set of LED taillights that look good on a NBS with Barn Doors. I saw these and figured i could possibly make them work.
These come in like 4 different colors.
So when they arrived I test fit them, the bottom reflector was hitting behind the hinge, looked and it and realized I could cut that part out and should be good to go. So here are all the pictures of how to do so.
First off you are going to need the following:
1. Phillips and flat head screwdriver
2. Clamps to secure the taillight while cutting
3. razorblade
4. some kind of adhesive, I used hot glue.
5. silicone if you arent sure if you sealed it back up well with the hot glue
6. Tool to cut plastic, I used a oscillating tool. you could also use a dremel.
7. compressed air to blow the plastic shavings out with.
So first off you have to remove the black box with wires in it and relocate it.
It was originally where the blue square is. you have to move it where the picture shows in the red circle.
These next 2 pictures show where you need to cut.
Here is what it looks like after you cut it.
Here is the piece you cut out. The reflector used to sit on the large flat piece. Clipped into the hole on each side.
Here is what it looks like before you set the reflector into the new hole.
Here is with the reflector set into the hole against the outside lens.
This is the outside view with the reflector in place.
Here is it all glued in and ready to install.
The next 2 pictures show the light installed and the new clearance behind the reflector.
Here is the drivers side light installed.
This picture is the light installed and camera up close with the camera flash off.
This picture is the light installed and camera up close with the camera flash on.
Here is the New and old comparison.
New LED on left side. Old stock on right side.
Here is the finished product!
Also here is the video from youtube of what the lights look like lit up .
Thank you all. If you have any questions let me know.
Hope you like it.
I know it's years later, but great write up. I just got the same taillights and was gonna trim em up today to put on my white barn door Tahoe. Thanks for affirming the process.
X-ray Nerd
