2002 tahoe lowered 2/3 sways really bad
LINTZ0718
LINTZ0718
It just lets the swaybar sit parallel like it's designed to do which makes it function properly. It's not going to "tighten up the front"; the only thing that will do that is new steering components. Nothing hits the inner tie rod.
Is not loose it sways but I put rear kit on and it great in the rear
LINTZ0718
LINTZ0718
Talking about the rear swaying. I had the same issue until I changed the rear springs.[/QUO
I installed drm rear trailing arm re locate kit and sway bar endlinks and got ploy bushings and now rear is tight. No swaying need to get poly for the front. Can’t afford sway bar kit yet. So I need to get ploy bushings and 1/2 inch shorter endlinks
LINTZ0718
LINTZ0718
Rear lower shot
LINTZ0718
LINTZ0718
22inch Texas fat 5 are on the list got the 20s from my work for free99 they were take offs and customer didn’t want them
JeffK
