2017 Denali XL extendable towing mirrors similar to 2500/3500 HD option
MT Elk Hunter
I understand that the wiring on the 2017 or newer Yukon/Denali and Escalade have proprietary wiring different than the Silverado/Sierra pick-ups. As a result, I have not been able to find extendable towing mirrors similar to the 2500/3500 HD option for my vehicle and towing needs. Strap-on extension mirrors are not a solution for my needs.
I am looking for information on how to prompt GMC to provide an over-the-counter mirror or any confirmed work-arounds to have a 2500/3500 HD GM or aftermarket mirror work.
Suburban13
1A auto carries some from trail ridge that were just released a month or so ago.
jay67chevy
Any luck getting these towing mirrors installed? Pics?
My XL is an SLE package with no built in turn signals, power fold, or blind spot detection. I'd buy a pair today if they mount right up to the factory mirrors. These look great compared to the snap on options.
M
MT Elk Hunter
Sorry for some bad news, but after a short delay while attempting a wiring work around I am returning the mirrors. Even though 1A Auto website advertises "GUARANTEED TO FIT" it doesn't since the 2017 Yukon XL, Denali has power folding mirrors. I looked at the GM Sierra/Silverado Service Manual schematics but the wire connector placement was too different and I didn't want to chance further testing to figure out the rewire since I have already caused control modules codes to appear.
CND17 BURBAN
Oh this is sad news I was hoping that these would be a great solution for towing.
I was going to order a set in the next few weeks.
Demer
Eagle, ID
In a dream world I'd take the mounting base section from the 1A mirrors and the rest of the parts/plugs from a 2500HD mirror. Not sure if anything would line up though and not willing to risk the $$ finding out.
M
MT Elk Hunter
That would be a good solution, but one will still have to figure out and re-position the wires in the 18-pin connector since the accessory configuration is different between many vehicle models. In a different thread I have seen that pgamboa has figured out, through a lengthy process, the wire positioning to adapt upgrade mirrors for the Sierra and Silverado models having different accessory packages. He even offers a custom built wiring harness, but again, the Yukon and Yukon Denali have still another wiring circuit. It is even worse if you have a diesel truck since some models have the mirror circuit shared with the seat circuit.
IamZ
Any updates? I have a 2016 Yukon XL Denali that I'll be using for towing but my mirrors are pathetically small!!!
cmatt
One option would be swapping in Escalade mirrors. They are plug and play. Although they don’t extend, they are much better than the OE mirrors.
Original mirror
Escalade mirror
M
MT Elk Hunter
Thank you for the suggestion. I wasn't aware that the Escalade mirrors are taller, but my needs are the extension mirrors due to trailer length. If I could obtain an accurate description of the wiring for each slot in the mirror and door plugs I could make my own harness adapter. Would you have that info or know where I could get it?
Original mirror
Escalade mirror
IamZ
One option would be swapping in Escalade mirrors. They are plug and play. Although they don’t extend, they are much better than the OE mirrors.i
Escalade mirror
Dang. Those are atleast better! I'll have to look into sourcing a pair.
cmatt
Yes, they’re much better than the originals. One of the best mods I’ve done.
NjA4207
