HOW-TO: 03-06 NBS Gauge cluster LED conversion
Bombsquad85
Northern VA
I usually use about 220 to 320 grit. Any more than 220 and it leaves really deep sanding scratches. You CAN however start with 120 or 150 for fast knockdown, then finish with 220 or 320. I have also used Emery boards as well and they work ok.
Do you just run the LED across the sand paper?
Bombsquad85
Northern VA
Yep, that's exactly what I do. Just be careful that you are holding the LED straight up, or else the top won't be flat, it will end up angled.
Hmmm would you recommend me desolder the ones I already installed to do this? Or try to sand them while attached?
And how much pressure should I apply or how much material should I take off?
Sorry for the million questions I just can't stand the hot spots they look ghetto af
S
ScottyBoy
Shreveport, La
You can try, but I doubt that you would be able to get at it good enough to sand it completely flat. Another option is to install LED strips on the white plastic portion of the cluster. I do that all the time now and have had great success with that, it produces zero hot spots.
Bombsquad85
Northern VA
And this is what a sanded down LED looks like next to an unsanded round tipped LED. View attachment 190216
Awesome thanks. I'll try sanding the LEDs I have now down if that doesn't work then I'll wrap the white frame in aluminum tape for some reflection. If that doesn't work I'll try the strips. Do you just solder to 1 contact
S
ScottyBoy
Shreveport, La
It depends on how long the strip is. I usually do it in two or three pieces to make it easier to secure it. On the one pictured above, I did in two sections and I soldered them together and to a plug that I soldered to the board. That way the white section can be lifted off and simply unplugged if anything needs to be serviced or repaired. Look closely just above that second stepper motor, and you can see that tiny white plug with two white wires plugged into it. The red and black wires on the strips are soldered to those white wires.
Here's another plug just like that one. I think I robbed these off an old computer printer that I gutted for any usable parts before throwing it away.
Bombsquad85
Northern VA
Here's another plug just like that one. I think I robbed these off an old computer printer that I gutted for any usable parts before throwing it away. View attachment 190218
I like it
91RS
GA
That looks great. Where do you get those LED strips?
Bombsquad85
Northern VA
@ScottyBoy thanks for the advice.
I looked at the HVAC controller opened it up and said nope haha. Looks like I'll be sticking to these unless you or someone else could drop a pic of the circuit board
Does this have to do with the guage cluster at all?
What repairs can fix the P0650 code?
Several repairs can fix a P0650 trouble code and include: * Replace damaged or burned out bulb or LED * Properly seat bulb for correct electrical connection * Replace damaged or corroded wiring and related electrical connectors * Straighten bent pins and repair or replace damaged terminals * Replace burned out fuse(s)* Replace damaged or defective ECM (rare) * Clear all codes, test-drive the vehicle, and rescan to see if any codes reappear
Is your check engine light working? Maybe it has something to do with your led bulb conversion. Something loose maybe?
Bombsquad85
Northern VA
Keep us updated.
Will do I'm gonna put "The Foreigner" on and figure these guages out. The only thing I can think is that my genius effort to make the light diffuse better i used aluminum foil. I think maybe it might be shorting something out intermittently. Maybe around the oil guage.
If it was me I'd look for really small scorch marks on the foil.
Bombsquad85
Northern VA
Thanks I'll look for that! All lights work, all guages work. The only thing that has been active weird since the swap is prior to the swap the oil guage was pegged at 80 now it occasionally goes all over the place and I get the annoying low oil pressure ding
varminpoolteam
