11 Burb 4x4 Transmission fluid change
SwedeBurban
Sweden
Hi,
Got a 2011 Suburban 4WD LTZ with 45k miles. No towing.
How often should you change your transmission fluid? I've got a 2011 Suburban LTZ 4x4 with 49.000 miles. I've read all from 50.000 miles and 100.000 miles.
Can i just use a electruc pump in the dipstick tube and suck some out now? Like this:
And later around 100.000 miles drop the pan and do a fluid and filter change?
How many quarts in just the tranny pan?
Thanks.
Best regards from Sweden
yugrus
You may, but you'll get less than a half of the fluid this way. Better option is the fluid transfusion through the ATF coolant line up at the radiator. Complete fluid exchange.
Sent from my VIVO XL using Tapatalk
yugrus
The transfusion is a very simple and easy process. Could be done solo, but it works better with manpower of two. You'd need a plastic tubing, 3/8" transmission cooler line fitting, container for the old fluid, the new fluid and the ability to disconnect the quick-connect metal ATF cooler pipe at passenger side at the top of the radiator. From there, it is straight forward and easy. Put the plastic tube on the fitting, click the fitting into radiator, put the other end of the tubing into container and start the engine. When bubbles begin to show in the tubing, shut it off and refill the tranny. Do that cycle until the fresh fluid flows out of the tubing.
Did this multiple times, works like a charm.
No risk of the "flush" machine damages anything.
SwedeBurban
SwedeBurban
Sweden
Thanks, I appreciate it. What size of plastic tubing do i need to the radiator?
Start the truck and just have it in park while draning?
yugrus
Ugh.. Can't tell you the diameter, yours will be metric anyway... Take a look at the cooler line, that's the internal diameter that you need.
Yes, idle the engine until you see bubbles in the clear tubing. Shut off, refill, then start again. The cycle lasts for about 5-8 seconds, so watch carefully. Transmission oil pump gets it out pretty quick.
SwedeBurban
SwedeBurban
Sweden
Realy appreciate it.
The fluid, does it gone come out of the radiator like this?
Like this:
Do i realy need a hose for the steel cooler line when its disconected?
/Eric
Regards from Sweden[/MEDIA]
yugrus
Yes, fluid comes out of radiator, not out of the steel line. Sorry, the memory became blurry here...
I've got 3/8" fitting like this https://www.ebay.com/itm/Hayden-Coo...d=112316615754&_trksid=p2054436.c100039.m2059
I don't remember paying that much though. Will make an actual picture later and post it here.
The fitting goes into radiator, and then there's no mess, no chance for the clear hose to come out. But from the video, the fitting is not necessary at all. Haven't tried that though.
No need for a hose on the line itself, IMHO.
You've got to be careful with how much you pump out at a time, watch the bubbles!
techbiker
I know it's a pain but I recommend dropping the pan and changing your filter before 100k even if you flush your fluid earlier. My magnet was covered with debris and my filter appeared to be full of gunk at 71k miles. Nothing wrong with a good fluid flush though!
yugrus
I second the filter change. Lots of debris on the magnets in the pan.
Red2017
I have performed many flushes with transmission flush machines with no issues. The trans always get put back what comes out. Easy and clean.
Clive
Just recently did this on my 2011 LT Tahoe @ 75,000miles. (see my post here) Additional info to that above:-
1. Removing the little clip that secures the line into the radiator required a little pick
2. If you dont use a fitting, the 3/8" OD plastic tube will pop out of the radiator. I just held it there while my accomplice ran the engine
3. The cross pipe below the transmission pan prevents the pan being pulled forward. I used a clamp to pull the exhaust down as far as it would go to give clearance to remove the pan.
4. I struggled getting the securing clip properly reinstalled. I think the better way would be to replace the spring clip first, then insert the transmission line, then reinstall the plastic retaining ring.
I used a total of 14qts Dexron VI for the flush/fill process.
RET423
I use and old tranny line bent to hang down below the radiator, start the engine and run till it sputters; then drop the now empty pan and replace the filter and sleeve.
Then I pour in five quarts and start it again with my purge line still connected, I pour in new fluid as the system is pumping out the old; when the color coming out becomes bright pink I shut it off and reconnect the tranny line.
Then I top it off normally. This method wastes a couple quarts but I get every drop of old fluid out every time without spilling a drop; well worth wasting a couple quarts in my opinion ;)
jackal78
