Whats a good obd2 scan tool that can scan abs and air bags
Goodinblack
I Like Tacos
Dirty South
Hmm a Tech2 for 250 dollars, wow, last time I looked these were over 3k and that included the Candi Module. I myself use a Genisys and on my Gms it has been a godsend. It is one thing to know the codes but you also have to have the diagnostic tree to do something with it. GM ESi DVD is your friend.
How much was that one?
ivin74
ivin74
05 NBS Nali
Htown, Texas
The Chinese Tech2 clone....which I think is actually the original manufacturer of the million dollar version is actually the exact same thing and only costs $250 with all of the cables and modules.
Wow, thats a deal than
TheAutumnWind
UrbanSuburban
The Genisys I use cost me $899 from Network Tool Warehouse, about 6 years ago, it came complete up to 2008 at that time and also came with all the cables for the pre 96 obd1 vehicles. I did update two years ago for a cost of $699 and that gave me Heavy Truck, Domestic, Asian, European and ABS/Airbag. TPMS is also part of it, I just did not get two of the accessories for it. It can also read almost all of the modules on the vehicle. For instance on the GM Suburban 2004, there are 14 different computer nodes on it, including the HVAC stepper motors, ABS both read and run tests, Bleeding Abs Solenoids, etc. Although I don't use it much I did also get the 4 channel ocilliscope module as well. Only problem with the unit has been the battery which was not much good, a rc car battery solved that. As far as the unit itself, the muxer unit is really too big for the cable that connects to the obd2 port.
blown240
Randy651
Does anyone have any thought on a handheld scanner or phone/tablet scanner that does Codes, ABS, Transmission, and Live data? I have a normal code reader but need more. I have GMC, Ford, and Chevy so I would like it to work on all. Any suggestions would be appreciated.
JayC33
New York
y
Sorry to revive an old thread, but if you are still looking for an answer to this, I also have the above mentioned BlueDriver, and it will do all you are asking here and then some. Great tool for the price.
MidwestMike
Southwest Michigan
And what does the Bluedriver do that the $20 - $40 unit don't?
"Officially licensed and certified for Apple and Android devices" does not mean a lot to me.
HACK BLOCK
NYC
so what you are saying is that any bluetooth obd2 reader will be able to read abs and airbag codes with the right app?
hillstrubl
