93BlkOnGreenPro's 2007 Yukon SLT Build Thread
93blkongreenpro
93blkongreenpro
Why are they flickering?
When they come back on, the slowly come up to full brightness. So on the camera it looks like a flicker. But that was 1 reason I went with these bc of that function and it looks classy and updated.
kwOH
Banned
Can’t tell if where you mounted the resistors is metal or plastic, if its plastic they will melt right through that, not tryin to be negative, that’s just the problem I was having In debating on to use resistors again or spend the money to have the BCM flashed. I had resistors and switchbacks on my NBS, and I just threw them down inside there and they melted right through a bunch of wires, they get extremely hot, so I took them out and got a flasher. Overall your lights look amazing tho man!!
93blkongreenpro
93blkongreenpro
It's metal, bc that's my grounding point for my hid ballast. And I did it for better heat dissipation.
kwOH
Banned
Perfect! Just wasn’t sure without me lookin at it in person.
If you get a chance, get a night shot, love the white on white light with the switchbacks and the headlights, looks so clean.
93blkongreenpro
93blkongreenpro
I messed up my rotation somehow, so I need to take them back out and re-rotate my projectors. I'll check on the resistors and contact hopefully tmrw.
Few quick pics. It took about 1.5 hours. I had to rerun the gps antenna to the outside of the truck. It would not pickup behind the radio.
And my cluster of entertainment wires.
Its nice that I can screen mirror my phone. That will actually come in handy saturday as the UNC game is on at 6 and I will not be home.
Sent from my SM-N910P using Tapatalk
when I put my gps antenna in I pulled up the front part of the dash (closest to windshield), there is small square spot underneath right by the daylight sensor and it fit perfectly right there, then just fed the wire back inside to the headunit., then I put a Sirius antenna as well almost directly in front of the driver under the same dash piece as there was just enough room in a slot there. I didn't want to have to run mine outside so I just figured it out.
93blkongreenpro
93blkongreenpro
I found out about the dash spot after the fact. I have since replaced the 4700 with the 4200NEX that had android auto/ apple car play, so no need for an gps antenna ☺
93blkongreenpro
93blkongreenpro
Fixed my front camera rotation finally.
I will get to the headlights tmrw.
The cutoffs are making an "X". It's bad.
But I swear to you, these Morimoito XB Switchbacks are brighter than our h11 headlights, lol.
kwOH
Banned
Did you use your OEMs for your retro or another brand? & what fogs do you have?
93blkongreenpro
93blkongreenpro
05Single
afraid of the dark
Nice, bothers me enough that you left the amber reflectors in lol, but at least now with leds you don't have the reflection of the amber turn signal bulbs anymore.
Gives it a cleaner look for sure.
I wish I had a nnbs just so I can have those morimoto fogs.
93blkongreenpro
93blkongreenpro
I tried to get that surround out of the lens and it was not budging. So after 5 mins of thinking I was going to break the lens, I said f-it. And the orange stays. I wanted to remove it, but not at the cost of buying another pair of head lights, lol. Maybe the oem's come apart easier.
05Single
afraid of the dark
Ah I see, didn't realize they were cemented in. Damn that sucks. Dont get me wrong , still some sexy was lights and great work sir
93blkongreenpro
93blkongreenpro
They arnt cemented in, but the lip was wrapped around and I felt like if I prayed too much, the lens was going to snap.
This week, I cleaned the garage. The infinite leaves on Bertha were killing my mood.
93blkongreenpro
93blkongreenpro
Headlight was out, but it ended up being a bad ground not allowing the ballast to ignite. Painted the cai cover bc it looked terrible. And I need to clean and oil the k&n. And added a nose for the Xmas spirit.
Sent from my SM-N950U using Tapatalk
93blkongreenpro
93blkongreenpro
Replaced rear shocks and front upper a arm yesterday. Didn't get around to the chrome tow hooks or sway bar bushings. Rides much better and no more clunk in the front.
93blkongreenpro
93blkongreenpro
Took a hr for the driver side. So about 2.5 hrs total. Not bad for my first time. Now to wash and wax.
BadDaddy2003
