Best $150 mods
HiHoeSilver
Away!
Chicago
I'm leaning towards the airaid mit because I'm getting exhaust for Christmas. It would add a little more sound. If anyone here has one, does it sound better than stock?
It has a bit more growl than stock when you're on it. Nothing I would call loud, really, but you'll know it's there.
HiHoeSilver
Away!
Chicago
Is that the kn box filter?
I use the Airaid dry filter in the stock box. The airbox mod is putting more /a larger hole for air to come in. Different guys have done it different ways. Sometimes known as the Swiss cheese mod.
D is for DENALI
don't know how I missed the Swiss cheese mod looking around this site, but, im going to do the 05single method... cut hole on bottom and install lower ram tube...
thanks for helping me find it!! lolz
I installed the airraid Mit tube/kn drop in and it adds a throaty growl under power..plus, more throttle response with less effort.
maybe I Will see a little more power with more air...
ill do it the same time as my "engine cover detail"..
mmeachem
Muffler swap, love my Magnaflow.
Can find most mufflers around 70-100 and around 50+ to weld it on.
Leds inside and out, help freshen up the look - less than $20
Hids definitely help with seeing at night - less than $50
CamReynolds
CamReynolds
im getting exhaust at christmas
mmeachem
can these go on top of my bull bar? it has holes for lights
Those are meant for flush bumper mounting, this is usually found on bull bars but double check the measurements
LED Light Bar Nilight 20 Inch 126w LED Work Light Spot Flood Combo Led Bar Off Road Lights Driving Lights Led Fog Light Jeep Lights Boat Lighting ,2 Years Warranty https://www.amazon.com/dp/B00WE47FVM/ref=cm_sw_r_cp_api_ Auxbeam 20" LED Light Bar 126W CREE LED Bar with 42pcs 3W CREE Driving Light Combo Beam Waterproof for driving Off Road ATV SUV UTV Jeep https://www.amazon.com/dp/B00T9BJ2GE/ref=cm_sw_r_cp_api_WTYbAbPJFS02F
about20ninj45
Lmao I bought it didn't install it. You guys said spent. In the process of ripping everything apart so I can install it
varminpoolteam
