Shocks with lowered suspension
blue01hoe
St. Pete Florida
For those of you who have their trucks lowered 2/3 or 2/4 what kind of shocks are you guys using, and how is the ride quality with them, and lastly best place to buy? thanks in advance.
SloZ71Hoe
East Texas
i have stock shocks all the way around... i do have shock extensions in the rear though.
B
blue01hoe
St. Pete Florida
i would use the rear shocks, but they are bead and need to be replaced. They are the oem ones, never changed out.
tybardy
everyone needs a Hoe
Gilbert Arizona
Im running stock Z71 suspension... and it rides like haggered dog shit!!
I am working on (hopefully) getting a bilstein setup. I hear those run really really nice
tx tahoe z71
Houston, TX
I have the same setup as Blue (Eibach 3" drop springs in rear, Bilstein HD's all around, shock relocators), and it rides really well, no complaints.
JD5527
Los Angeles
Can anyone post part # of shock extension or shock relocators? I just installed 2-3ground force and ass end sits high.
Narco
Atlanta
i just ordered Bilsteins E380s from Max...mine should be dropped 3/4 in a little over a week from now
blueflamed03
Oklahoma
if your still using factory shock loctations, and or shocks, yes, it will sit higher. If you add relocators and reinstall factory shocks it should lower. But if it still doesn't sit as low as you'd expect, swap rear shocks, if you have the factory big black shocks.
Narco
Atlanta
yup, ill be adding the new bilsteins and using the extenders
B
blue01hoe
St. Pete Florida
It seems like the majority vote goes to bilstein, so bilstein it is. Gonna order them tomorrow or monday. Thanks for the help guys, much appreciated.
Byoung1330
Cookeville tn
I have stock up front and Gabriel in rear with shock extenders. Wondering if the beltechs are any good. Black or gray ones.
dizhai
