Tune is set up for the stall. Everything was done by the same shop. Hopefully it's just something really simple to fix.Do you have a high stall, 3000 or over? Is your tune set for your stall? You might check this out:https://ls1tech.com/forums/automatic-transmission/1302391-trouble-code-p0757-4l60e.html. Could you just need your tune set for your stall.
EDIT: I just checked the link and read through the thread. I don't know now. I talked to the trans guy before and he said it might be a solenoid. I'm hoping he has the proper scanner to see what the trans is doing. Thx for the link Red.
