05Single
afraid of the dark
- Joined
- Feb 26, 2015
- Posts
- 8,243
- Reaction score
- 11,639
What's up with that tree branch on the back?
This came stock with the 2013 LTZ.
Here are a few pics of the cover.
View attachment 182125 View attachment 182126
Zoom in and you will see 4 tabs at the top that slide in under the chrome strip.
There are 2 twist tabs at the bottom that push through holes on the underside of the bumper and twist lock the cover so it will not fall down.
Check out this Street Scene cover.
http://www.streetsceneeq.com/chevy-suburban-tahoe-07-13-rear-hitch-cover.html
It says 07-13 and around $100.
@swathdiver
6 days waiting for shippingPolished all the chrome on the truck tonight. The wheels looked good from far... but far from good.
They needed some elbow grease and a bit of Flitz to shift the grime and hard water deposits. Everything is clean and shiny now.
Before
After
Polished the front mesh grill out in between all the gaps. What a PITA, but much needed.
One LED license plate light had wiggled loose, so I pushed that back in tight and it worked.
Found my front passenger door handle was broken just like the rear passenger did last spring. Grrrr...
Found a replacement for $18 on Amazon Prime, but with the Labor Day weekend, the part won't actually arrive for 6 days. Grrrr...
Making headway slowly.
girl please!What's up with that tree branch on the back?![]()
6 days waiting for shippinggirl please!
Wheels look great , I'm assuming I can find that stuff anywhere ?
What pad did you use for applying the Aqua tech?
Note the knurled pot metal insert still stuck to the door.
