95escahoe
What is everyone running for the resistors for front autoride shocks? I want to put on some bilsteins these 150k mile oems can't be good anymore. (My front shocks are original rears have been replaced)
Ive done the turn the whole system off thing before but i want to keep the rear shocks functioning.
Interested in this too
Chubbs
RAaaaHhhhhhhhh
Have literally been waiting all week to install some new junk on my truck and replace some other things but the a$$hole P/O has wheel locks on the front 2 tires & no F'n key for it!! How did I not notice this?? I went around & loosened every lug nut, re-torqued to spec so I know that I could break them loose on the roadside & I missed the wheel locks? Or forgot about it?! IDK but I'm dumber than the last person, obviously. Now what? A whole new project?
RAaaaHhhhhhhhh
You might have to sacrifice an impact socket or two to get them off.
PG01
Up here to the right
Tighten the balls off the reg lugs, without breaking them, then start working at the locks with whatever you got to work with.. hopefully the PO put them on last (after all the other lugs are on and torqued, like you're supposed to) and didnt torque the **** out of the locks...good luck.... did you search the truck for the key.... where the jack is or jack tools, glove comp, console, under seats etc..... i used to keep mine with the jack...
Chubbs
I have been through every nook & cranny in that truck. Obviously, finding the key is the single best way to remove the locks. I already dug through the tire remov' tools cubby looking to see what was present/MIA/check the spare tire & ratchet system.
The other 2 wheel locks of the set weren't even on the back tires because they had been replaced, while the front tires had not. My local stores don't carry anything that will help me.
Is it true that if I buy another set of wheel locks (which I have to do anyway) the key included will in no way fit the old locks still on my truck, even if it's identical make/model?? None of the stores even carried the same model of Dorman wheel locks on my truck. They have the same make/model, wrong size. Every size EXCEPT a GM 14x-1.5. How in the hell is that even possible. 1 store had a Dorman 14x2.0, same make/model & appeared to have the same lock & key pattern. It looked to me like it would fit but the store clerk thought I was an idiot for trying to buy the wrong size. PLUS.. all 3 kits they had on the shelf in 14x2.0 were taped closed, so there's no way I could return any 1 of them if the key didn't work; BULL$HiT!!!
What's the proposal for modifying 1 of my sockets? Grind it out to fit the pattern on the old locks? There's no way... the lug openings on my wheels are a closed design & super deep. The locks themselves are smooth @ the top 1.5" with the keyways design at the very bottom 1/2", so none of the wheel lock removers I found where not only too short, but also too large in diameter to fit in the lug hole. It's a screwed up deal; only a tire shop will have the tools to extract those things & even then I doubt 100% of them will have what is actually required. I don't want some bird brain tire tech using the wrong $hit & completely FUBAR the things. I will have to order a few dif items online if I'm to remove the locks myself, which is ideal.
kwOH
Banned
Filled the Escalade up with Shell V Power (93) usually go with Valero 93 figured I'd try it out, installed the smoked fogs a few days ago they look great
V-power ftw, fogs look gooood. Your nbs pickup?
Sent from iPhone 7 plus using Tapatalk Pro
95escahoe
Thanks, and yup 03 Silverado RCSB Z-71, pretty much stock, crystal clear headlights & turn signals, billet grille and bow-tie, LED tails, LED 3rd brake light, LED interior lights, dark tints I think 15/20%, good truck to have around
kwOH
Banned
Double build thread.......[emoji106] would love to see some more pics of the truck.
95escahoe
Maybe, I'll get some I thought I had some on my phone
Chubbs
I got up early and swapped out the modified torsion-bar keys & installed the shock extenders; my truck is leveled now. I called around to get some costs for tire mount & balance...$60-$80 and 1 place will charge extra to remove the 2 wheel locks. i haven't done it this way in a long time but I'm pretty sure that it only cost $20-$30 total back then. $60 for mounting + $90 for alignment,
:wtf:
I'm going to go return the torsion key tool, buy some Ejuice, & see how it rides. The cheapest quote that I have to mount/balance/align is @ a Chrysler dealership so I may have to roll as-is for a few days.
Countryboy07
Drove to GA to visit my brother for the weekend. Had a bit of a mishap on 75 about two hours north of my brother...
Got another tire put on so we could venture back home on Monday
Was browsing CL down here just messing around and came across these wheels with basically new tires for $850.
So, something good came of our mishap.
Drewphil
