NBS Custom Backup Cameras
Crippin87
I have 2 back up cameras for NBS trucks, both have guid lines for backing. These are brand new cameras only thing I have done is test them and mount them to make sure everything works as it should. They are plug and play so just pop your factory one out and put this one in its place. All you need to do is run your video rca and tap a power source. These work just like the factory buttons by retaining the functionality of the window release, just upgraded. You will also get 300m of video cable and the power/ground. $125 each. Any questions just ask.
Crippin87
Crippin87
It's GM. I modified them to fit the camera inside but still function as normal.
So they're used GM hatch buttons with aftermarket cameras mounted in them? And you didn't really mean 300 meters of video cable did you? Also, I see one has a set of wires that the other doesn't?
Crippin87
Crippin87
Lmao, no I did not mean 300 meters, I will have to let you know what I meant when I get home from work. But yes, they are factory hatch buttons that I modified to fit the camera and still be functional. As far as the wires go, it just depends on your truck what you need. I have an 06 nali and mine didn't have the wires but some other models use them. Idk what they are for so I would just take a look and see what style you have.
Crippin87
Crippin87
It has 19ft of video cable. Idk what I was trying to put in my first post lol
JayC33
New York
Sorry if this is a dumb questions, I don't currently have a back up camera and I'm getting ready to install an after market he and cam. Will these work with an aftermarket he or will OT require modification? My aftermarket unit came with a license plate mount camera
Crippin87
Crippin87
It would work just the same. Instead of mounting your license plate camera up just put this one in your hatch instead and run your wires to it.
Crippin87
Crippin87
can this be intergrated into the factory nav unit of an 06 denali with Onstar as well?
I'm not sure really. If you have a back up camera that you are using now I would assume it work. Mine is an 06 Denali with onstar, but I put a different head unit in. I didn't see a video input on the factory that I took out.
ScottyBoy
Shreveport, La
Man that's sweet. I'd like to do a slick camera install like that, but my hatch button actually has a keyhole in the button. I'm not sure what year they stopped putting a key lock in the button, but I don't want to do away with mine. I've read about people on here who have had problems opening the hatch when the power lock actuator failed. Plus the fact that I already have been in a situation where my battery went dead, and I had to unlock the rear hatch to get my jumper cables from underneath the third row seat where I store them at.
Crippin87
Crippin87
Thanks! Yea that wouldn't be bad to have the the key slot to fall back on in emergencies. Mine never had one so I never had to worry about it, I just use the key fob or crawl through if I have to lol
uscharalph
I'll take one. It will work on my 2005 GMC Yukon SLT, correct? PM your paypal address and I'll forward to you the $125.00 and my shipping address.
X-ray Nerd
