Oil pressure sending unit range ???
kbuskill
kbuskill
NE. FL.
I'm pretty sure @kbuskill is right on this one. 5v reference. 5v return is 0 psi, 0v return is 80+psi. But you're right, might be worth checking with a meter.
Yeah no need to check... when my gauge was reading 0 psi I had a code P0523 which is oil pressure sending unit voltage HIGH.
I had thought about the resistor first but as was mentioned above it would just read even higher.
Still wondering if drilling or filling the hole would effect it.
What about a resistor on the 5v reference line? If I'm not mistaken, the sensor acts as a variable resistor to the 5 v line and decreases the voltage as the pressure increases so if the 5v line is decreased to say 4.5 volts then the output should also be decreased by .5 volts.
HiHoeSilver
Away!
Chicago
This is true, but what we need here is a higher return voltage. No matter where we put a resistor, it's going to be lower.
kbuskill
kbuskill
NE. FL.
What we could do is steal another source of power and resist that one to whatever we want and introduce it to the circuit....or a AA battery is 1.5v.....food for thought @kbuskill
Yeah I was thinking about that but there again, I would like to maintain actual functionality just incase something were to actually go wrong, that is why I keep going back to modifying the pressure switch and not the voltage.
HiHoeSilver
Away!
Chicago
If you leave the sensor in the circuit, it will still do its thing. Just need to juice it a little to bring it into range.
kbuskill
kbuskill
NE. FL.
Perhaps I should just actually reduce the pressure... what I mean is, I have been wanting to add the oil cooler lines and an external oil cooler and have even kicked around the idea of remote mounting the oil filter so I could run a larger filter. If I add that stuff into the system it will increase the volume of oil as well, which is a plus as well IMO and it should also lower the pressure somewhat. Or am I crazy?
HiHoeSilver
Away!
Chicago
Seems like it might...
Are you sure you don't already have an oil cooler? My Denali does. It's small so I was thinking if you have one you could get a bigger one and the lines are already there.
M3kanic
I wonder if the aftermarket corvette oil coolers would work. If they do that would make the whole process easier.
kbuskill
kbuskill
NE. FL.
Negative... mine does not have an oil cooler. I have had the front end off when I added a bigger trans cooler inline with the factory one and I do my own oil changes, and other stunts, and it definitely does not have any oil cooler lines attached to the ports above the oil filter... only the cap.
kbuskill
kbuskill
NE. FL.
Which cooler are you speaking of? Do you have a link?
I can get the factory cooler lines for about $50 and a decent cooler for about the same OR since I already have a remote mount dual oil filter setup all I would need to buy is the adaptor to go in place of the factory oil filter and I could run it that way with a cooler inline.
I know if I run the cooler off of the factory oil filter location then it should cause a drop in pressure because the oil pump pushes the oil through the filter first before going into the block and up to the pressure switch.
If I run it from the factory cooler line location I am not certain if that would be PRE or POST pressure switch.
kbuskill
kbuskill
NE. FL.
Something like this that will allow you to run something like a TruCool
http://www.improvedracing.com/oil-c...ette-oil-cooler-thermostat-adapter-p-369.html
When you said Corvette oil cooler I thought you wereeaming the actual cooler that goes in front of the radiator, not the adaptor.
This is the one I was looking at:
http://www.jegs.com/i/Hamburgers/497/3327/10002/-1
The one you posted bolts up to the factory cooler port location and I am not 100% sure if that would cause the pressure drop I am looking for.
M3kanic
I was trying to give you ideas. I am have high temps while towing and ran across it doing research but have not found anyone using it on a sub.
But maybe you could port out the area below the sensor to make a "dead" spot.
moto
