I want these Escalade wheels on my 2010 Tahoe
chilleblanco36
From what I've read the OEM wheels will not fit without issues, maybe because of the offset. Im going to order replicas. I'd like to see pics of these on a Tahoe if possible. I also plan on running 285/45/22 for tires, Bridgestone Duellers.
Sent from my SAMSUNG-SM-G935A using Tapatalk
massivespl
I'm not mean, I'm honest.
Michigan
OEM wheels should fit. I like a 305/40/22 tire more then a 285/45/22
Fosscore
Check the offset, but GM wheels are usually +31 offset. I know this is a different year but my 06 went from 16 to 20 to 24 and bolted right on.
My 13 has 20s and the same year Escalades run 22s OEM.
Same 6 lug pattern. Check out this thread for some technical info further explaining. You should have zero issues.
https://www.rsracing.com/TechWheel.aspx
chilleblanco36
chilleblanco36
The offset of the OEM was different. I'm going with replicas for the cost. I just want to see some on a Tahoe before I pull the trigger. I know they will look good
I got this off a set on eBay. Will this work for sure with no issues?
Bolt Pattern: 6x139.7
Offset: 24mm
Center Bore: 78.1
A member here is selling a set and I think I'm going for them.
chilleblanco36
chilleblanco36
Just when I thought I had my choices narrowed down to the ubiquitous CK375 or newer Denali Y-spoke 22s...
I'd like to see more pics of this. Have any straight side shots?
I have searched and searched and saw a lot of pics. That pic there is about the best I've seen. Others had me worried. Then I had them photoshopped to a truck the color of mine. The pic above sold me
Yes- seeing them on your color of truck makes a difference. I can't find decent pics of the wheels I want on Graystone Metallic trucks. I find plenty of them in 24s or 26s. But I can't get an accurate idea because the bigger wheels give a false impression from all the extra chrome.
chilleblanco36
chilleblanco36
I personally don't want to go with anything larger than a 22.
chilleblanco36
chilleblanco36
ThatOneGuy
It appears to still have a little rake and that's what I want to keep. What leveling kit did you use, and what rear suspension do you have? I have the "premium smooth ride" with the RP0 code of ZW7.
Its just 2inch lowering McGaughys springs with monroe shocks. I almost installed 3inch lowering springs but i wanted a bit of rake as well so i went with 2inch.
Its getting a 2/3 lowering kit.
BADRIDES
I have Belltech rear coils for sale for anyone looking for a set?
